>> It's interesting that those are all :CHK records, is that because they're the
>> only ones you're looking at using caget?
No, we are looking at several other PV's (about 7K+) in this utility.
So far, the only ones that have failed are these CHK records.
I checked with the owner of these PV's and nothing untoward seems to have happened at these times.
>> Good. Do you have any information about messages output when the core dump
>> occurred?
Unfortunately, no. I'll see if I can keep some of the logs around a bit longer.
>> You could try commenting out the call to pthread_key_delete(getpthreadInfo);
>> on line 148, but actually I think you can go further, as one thing that we
This is most likely the cause; I will try these suggestions out and see if that fixes it.
>> Alternatively just upgrade to R3.14.12.1...
In this particular case, I'm fairly certain there's a way we can do this.
Let me try this out as well.
Thank you for your assistance.
Murali
-----Original Message-----
Sent: Friday, May 06, 2011 3:17 PM
To: [email protected]
Cc: Shankar, Murali
Subject: Re: caget very rarely core dumps in osdThread.c
Hi Murali,
On Friday 06 May 2011 16:04:07 Shankar, Murali wrote:
> As part of tracking down failures elsewhere, we ran into some core dumps of
> caget from EPICS base version R3-14-10 on linux. These were caget's for
> different PV's and at different points in time.
> Apr 27 07:46 core.21238 - caget GTW4:MEM:CHK
> Apr 27 13:54 core.25030 - caget MCCELOG:MEM:CHK
> Apr 30 14:30 core.26546 - caget PROD03:MEM:CHK
> May 3 13:27 core.12026 - caget DAEMON4:DISK:CHK
> May 5 13:20 core.4340 - caget PROD01:PROC:CHK
> We do have symbols and all the core files point here
occurred?
> (gdb) bt
> #0 0x0098f9b1 in createImplicit () at
> ../../../src/libCom/osi/os/posix/osdThread.c:466
> #1 0x00990064 in epicsThreadGetIdSelf () at
> ../../../src/libCom/osi/os/posix/osdThread.c:618
> #2 0x009828b2 in cantProceed (msg=0x9a0a8c "start_routine") at
> ../../../src/libCom/misc/cantProceed.c:63
> #3 0x0098f2a6 in start_routine (arg=0xb7d00598) at
> ../../../src/libCom/osi/os/posix/osdThread.c:309
> #4 0x007423cc in start_thread () from /lib/tls/libpthread.so.0
> #5 0x005a9f0e in clone () from /lib/tls/libc.so.6
Line 309 of src/libCom/osi/os/posix/osdThread.c is checking the return value
from pthread_setspecific(), which the main page says may fail with EINVAL if
the key value is invalid. That seems like some code is trying to start up
another thread after the process has already run its atexit() routines, in
particular the myAtExit() at line 115 in that file.
have done since R3.14.10 is to delete the myAtExit() routine completely — the
cleanup it was doing really isn't necessary; you can just comment out the call
to atexit() on line 294 that registers it. Doing that has removed a lot of
strange shutdown issues that we used to get on Linux.
HTH,
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
- caget very rarely core dumps in osdThread.c Shankar, Murali
- Re: caget very rarely core dumps in osdThread.c Andrew Johnson
RE: caget very rarely core dumps in osdThread.c Jeff Hill
<2011>
2025
2026
<2011>
2025
2026
