1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Does EPICS Base support multi-thread on vxWorks 6.3?
To: [email protected]
Cc: [email protected]
Date: Tue, 10 May 2011 11:08:53 -0500
Hi Lorna,
On Monday 09 May 2011 22:38:51 [email protected] wrote:
> What is a munch file? Why doesn't my bin\vxWorks-ppc603 folder include a
> vxTestHarness.munch file?
If you built EPICS Base properly, that file should be present for all vxWorks
architectures, e.g:
tux% cd base-3.14.12.1/bin/vxWorks-ppc32
tux% ls -l *.munch
-r-xr-xr-x 1 anj aesctl 1416603 Apr 26 15:43 callbackTest.munch*
-r-xr-xr-x 1 anj aesctl 1864447 May 10 10:47 softIoc.munch*
-r-xr-xr-x 1 anj aesctl  613149 May 10 10:33 vxTestHarness.munch*
> What is and how to link all the vxWorks binaries into a single .munch
> file??
A .munch file is a binary executable for vxWorks. It's created by linking
together all your object files and libraries into a single file, generating
and compiling a C source file that combines all of the C++ static constructors
and destructors present, and then linking that object file into the executable
as well.  The name "munch" comes from the Wind River tool used to create the
static constructor/destructor list file, although EPICS Base uses its own
version of that tool written in Perl.
Here's the vxTestHarness.munch file being created inside base/src/libCom/test:
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ldppc -r -o
vxTestHarness  -L../../../../lib/vxWorks-ppc32/ -
L/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/powerpc-wrs-
vxworks/lib ../../../../bin/vxWorks-ppc32/vxComLibrary.o epicsCalcTest.o
epicsAlgorithmTest.o epicsMathTest.o epicsEllTest.o epicsErrlogTest.o
epicsStdioTest.o epicsStringTest.o epicsTimeTest.o epicsThreadTest.o
epicsThreadOnceTest.o epicsThreadPriorityTest.o epicsThreadPrivateTest.o
epicsExitTest.o epicsTimerTest.o ringPointerTest.o ringBytesTest.o
epicsEventTest.o epicsMutexTest.o epicsExceptionTest.o macEnvExpandTest.o
macLibTest.o taskwdTest.o blockingSockTest.o epicsMessageQueueTest.o
epicsRunLibComTests.o epicsThreadPerform.o epicsMaxThreads.o buckTest.o
cvtFastPerform.o -lCom
/usr/local/vw/vxWorks-6.8/utilities-1.0/x86-linux2/bin/nmppc vxTestHarness >
vxTestHarness.nm
perl ../../../../bin/linux-x86_64/munch.pl -o vxTestHarness_ctdt.c
vxTestHarness.nm
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -c
-DCPU=PPC32 -DvxWorks -include
/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -O2 -Wall -mstrict-
align -mlongcall -fno-builtin -MMD -fdollars-in-identifiers -I. -I../O.Common
-I. -I.. -I../../../../include/os/vxWorks -I../../../../include -
I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -
I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ldppc -r -T
/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/tool/gnu/ldscripts/link.OUT -o
vxTestHarness.munch vxTestHarness_ctdt.o vxTestHarness
Installing created file ../../../../bin/vxWorks-ppc32/vxTestHarness.munch
Are you using the EPICS build system?  The above steps are all automatic when
you ask it to create a vxWorks executable.  If you're using Wind River
Workbench the equivalent seems to be a "Downloadable Kernel Module" project,
but I've never tried using Workbench to create EPICS applications.
- Andrew
An error is only a mistake if you don't learn from it.
When you learn something from it, it becomes a lesson.
Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
Prev: RE: Announce: seq-2.0.13 Mark Rivers
Next: Re: Announce: seq-2.0.13 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
Next: Re: Does EPICS Base support multi-thread on vxWorks 6.3? lorna . zhang
