1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Announce: seq-2.0.13
Cc: [email protected]
Date: Wed, 11 May 2011 02:03:49 +0200
Am Dienstag, 10. Mai 2011, um 18:02:46 schrieb Mark Rivers:
> I've now tested 2.0.99, which I understand is a development version of what
> will become 2.1.0.
Many thanks for taking the time to do this.
However, 2.0.99 is very much out-dated (by no less than 274 patches), so it
probably doesn't make much sense to waste time on the build failures you
experienced. I have put a snapshot of the current state of the repository on
the web server, the URL is
http://www-csr.bessy.de/control/SoftDist/sequencer/releases/seq-
snapshot-2011-05-11.tar.gz
 (BTW, I just added a patch that automatically creates and uploads such a tar
ball every time I upload to our web server.)
Could I persuade you to try to compile this version on windows?
If you build against a recent version of EPICS base (I think 3.14.11 is
enough), then you can run the automated test suite (which is still far from
providing complete coverage but is helpful nevertheless) by executing
        make runtests
at the TOP directory (after building, just like with EPICS base). Note that
some of the tests are supposed to run for half a minute, so be patient.
I also hope I can make a release candidate for 2.1.0 as soon as possible, and
that you will be able to test if it cleanly builds (and run the test suite) on
windows. The main hurdle for me at the moment is how to run the test suite on
vxWorks and RTEMS.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: Announce: seq-2.0.13 Mark Rivers
Re: Announce: seq-2.0.13 Benjamin Franksen
Prev: Re: Does EPICS Base support multi-thread on vxWorks 6.3? Andrew Johnson
Next: Disconnected PVs Andrew C. Starritt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Announce: seq-2.0.13 Mark Rivers
Next: Micos MMC-100 ulrik.pedersen
