1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Disconnected PVs
To: EPICS Tech Talk <[email protected]>
Date: Wed, 11 May 2011 10:29:17 +1000
Hi all,
As part of the "ca.py - Throws error - workaround" thread there was some
discussion whether a CA client should call ca_clear_subscription when it
detects that a server has disconnected and presumably re-subscribe when
the server re-connects.
Although the CA library automatically maintains the subscription, wouldn't
it be better that when the PV re-connects, the client should do a ca_get
(or ca_get_array or ca_get_array_callback) and a new ca_create_subscription.
I would do this because the nature of a PV might have changed and a new
ca_get would ensure that the client has the latest associated data
(e.g. precision, EGU, enumeration values), and a new subscription because
the field type and/or number of elements may have changed as well.
Although such PV changes are relatively rare, they do occur.
Any counter arguments?
Andrew Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: Disconnected PVs Matt Newville
Re: Disconnected PVs Andrew Johnson
Prev: Re: Announce: seq-2.0.13 Benjamin Franksen
Next: asynPortDriver callbacks to I/O Intr, how to propagate an error? Angus Gratton
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: What is the difference between VxWorks intConnect and pciIntConnect 王林
Next: Re: Disconnected PVs Matt Newville
