1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asynPortDriver callbacks to I/O Intr, how to propagate an error?
To: tech-talk <[email protected]>
Date: Wed, 11 May 2011 10:59:20 +1000
I have some asynPortDriver-derived driver classes for various pieces of
hardware, most of which are updated when data changes in a DMA read (ie
the background monitoring thread calls setIntegerParam() then calls
callParamCallbacks())
The records are all using I/O Intr so they only scan when required.
Sometimes the DMA read indicates that a piece of hardware has gone
offline. In this case, I'd like to have records using that port scanned
and updated to INVALID severity, and also see an error logged on the
console.
If was using periodic scanning, I believe I could override readInt32()
or equivalent to return asynError status. However, if I want to keep
using I/O Intr then I can't see any way to do this, either with
asynPortDriver or with asyn.
What I'm imagining would help me is a method with a name like
setParamErrorFlag(), that I could call before callParamCallbacks() and
that would propagate the error state back to the record. I'm still very
much an asyn newbie though, so maybe I'm looking at this the wrong way.
Thanks in advance for any tips. If this feature doesn't exist and might
be useful, I'm happy to have a shot at implementing it with a view to
submitting a patch.
- Angus
Angus Gratton
Computer Control Specialist
Department of Nuclear Physics
Australian National University
Ph: +61 2 6125 2096
RE: asynPortDriver callbacks to I/O Intr, how to propagate an error? Mark Rivers
Prev: Disconnected PVs Andrew C. Starritt
Next: Calculation in SNL/SEQ liuping
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Disconnected PVs Andrew Johnson
Next: RE: asynPortDriver callbacks to I/O Intr, how to propagate an error? Mark Rivers
