1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: string "no alarm" color in edm textupdate, text monitor behavior seems to vary
To: [email protected]
Date: Thu, 12 May 2011 09:29:48 -0700
I've always been under the impression that even if you check "alarm sensitive" on the edm widgets, when the PV is in the no alarm condition the color will be the foreground color configured for the widget.  Usually I make this green so I don't test this much.  On my desktop installation, if I make the foreground color something else like black, the text is black under the no alarm severity, but goes yellow for minor, red for major.  In the ALS control room edm installation, though, it changes the text color to green in the no alarm condition regardless of the foreground color configuration.  Is this an edm version difference, is there some display parameter its looking at, or what?
Carl
Carl Lionberger
Software Developer
LBNL Engineering Division
510 486 7503
Re: string "no alarm" color in edm textupdate, text monitor behavior seems to vary John William Sinclair
RE: string "no alarm" color in edm textupdate, text monitor behavior seems to vary Allison, Stephanie
Prev: Re: Pro-Dex OMS MAXv card reading limit-switches Martin L. Smith
Next: Re: string "no alarm" color in edm textupdate, text monitor behavior seems to vary John William Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
