1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernetcommunications? CryoCon RS-232?
Cc: [email protected]
Date: Fri, 13 May 2011 15:06:57 -0500 (CDT)
Jay, Mark
I looked at this a few years ago. At the time (where do the years go!) the Ethernet module only supported the FINS protocol, for which you would need develop EPICS support.
Things may have changed, but I'd read the documentation very carefully and make sure before making any assumptions. FINS is the OMRON native protocol, but don't think you would have a terribly hard time making the asyn framework support it.
Cheers
Richard Farnsworth
Controls Group leader,
APS Engineering Support Division,
----- Original Message -----
To: "Jay Steele" <[email protected]>, [email protected]
Sent: Friday, May 13, 2011 2:32:06 PM
Subject: RE: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN	Ethernetcommunications? CryoCon RS-232?
Jay,
I looked at their documents. The serial port supports Modbus slave. I could not determine if the Ethernet does as well, but I suspect so. Then you do don’t need to write a driver at all, you just read and write PLC registers via Modbus to communicate with EPICS.
From: [email protected] [mailto:[email protected]] On Behalf Of Jay Steele
Sent: Friday, May 13, 2011 2:08 PM
To: [email protected]
Subject: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernetcommunications? CryoCon RS-232?
Hi EPICS folks,
Has anybody developed a EPICS module to communicate with the OMRON PLC SYSMAC CJIM CPU12-ETN using Ethernet TCP/IP sockets? I'm prepared to develop such a module using the asyn framework, but wanted to check if anybody has done this already. We use the OMRON PLC for cryogenics and vacuum control for our bionanoprobe X-ray fluorescence instruments. I see references to Omron PLCs on the EPICS website from Paul Hamadyk and Mauro Giacchini, but only for RS-232 communications.
Has anybody developed a EPICS module for RS-232 communications with CryoCon temperature controllers? Again I'm prepared to develop such a module using the asyn framework, but wanted to check if anybody has done this already.
Jay Steele
Xradia Corporation
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
RE: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernetcommunications? CryoCon RS-232? Mark Rivers
Prev: Re: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? nick.rees
Next: RE: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? Jay Steele
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernetcommunications? CryoCon RS-232? Mark Rivers
Next: Re: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? nick.rees
