> ----- Reply message -----
> From: "Jay Steele" <[email protected]>
> Date: Fri, May 13, 2011 20:15
> Subject: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232?
> To: "[email protected]" <[email protected]>
> Hi EPICS folks,
> Has anybody developed a EPICS module to communicate with the OMRON PLC SYSMAC CJIM CPU12-ETN using Ethernet TCP/IP sockets? I'm prepared to develop such a module using the asyn framework, but wanted to check if anybody has done this already. We use the OMRON PLC for cryogenics and vacuum control for our bionanoprobe X-ray fluorescence instruments. I see references to Omron PLCs on the EPICS website from Paul Hamadyk and Mauro Giacchini, but only for RS-232 communications.
> Has anybody developed a EPICS module for RS-232 communications with CryoCon temperature controllers? Again I'm prepared to develop such a module using the asyn framework, but wanted to check if anybody has done this already.
> Thanks,
> Jay Steele
> Xradia Corporation
Jay,
Yes we have a asyn driver that supports OMRON's FINS (Factory
Intelligent Network Service) protocol but only for UDP. I found that TCP
was a bit slow but if you really want TCP then the OMRON document W421
"Ethernet Units - Construction of Applications" has some example code.
My driver doesn't support all the FINS commands but does 16-bit and
32-bit read & writes to data and auxiliary memory, core I/O and access
to some status information. Tell me what you need and I'll see if it
will work.
Paul.
- EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? Jay Steele
- Re: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? nick.rees
- RE: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? Jay Steele
Announce: seq-2.0.14 Benjamin Franksen
<2011>
2025
2026
RE: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? emma.shepherd
<2011>
2025
2026
