1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Announce: seq-2.0.14
To: <[email protected]>
Date: Mon, 16 May 2011 11:36:07 +0200
The only user relevant change w.r.t. 2.0.13 is a fix to enable building on
Windows.
Changes since 2.0.13 (detailed)
  * bumped version to 2.0.14
  * parameterized upload target in top-level Makefile
  * fix windows build by using osiUnistd.h instead of unistd.h
Download & Install Instructions
http://www-csr.bessy.de/control/SoftDist/sequencer/Installation.html
For the impatient, here is a link to the tar ball:
  http://www-
csr.bessy.de/control/SoftDist/sequencer/releases/seq-2.0.14.tar.gz
Repository
  darcs get http://www-
csr.bessy.de/control/SoftDist/sequencer/branch-2-0-13/
Repository Browser
  http://www-csr.bessy.de/cgi-
bin/darcsweb.cgi?r=sequencer%20%28branch%202-0-13%29;a=summary
And finally...
Recent developments on the main trunk
I have finally found a way to automatically run make the test suite under
vxWorks. This is now also documented in the Installation section of the
manual.
So far, all my tests succeed on linux-x86, linux-x86_64, vxWorks-68040, and
vxWork-ppc603; however, the test suite is still far from providing full
coverage, so this doesn't have to mean anything.
>From now on, each time I update the documentastion on the web site, I will
also generate and upload a snapshot tar ball, named seq-snapshot-
<sate>.tar.gz; hopefully this will make it easier for people to download,
build, and test the development version. I will try to upload only versions
that cleanly compile on my development machines and where the test suite
runs throught w/o failures.
The latest snaphot is always available as a symbolic link with the name
  http://www-csr.bessy.de/control/SoftDist/sequencer/releases/seq-snapshot-
latest.tar.gz
Thanks to Mark Rivers I could fix a number of problems in the code and the
Makefiles which became apparent only when building on Windows (both under
cygwin and using the native tools). Patches that hopefully fix these
problems are contained in the latest snapshot which I uploaded a few minutes
ago.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: RE: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? Paul Hamadyk
Next: Re: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? Wesley Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? Wesley Moore
Next: Channel Access not connecting Bruce Hill
