1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Channel Access not connecting
To: Techtalk <[email protected]>
Date: Mon, 16 May 2011 22:12:00 -0700
I've been having trouble with one linux machine where my IOC's appear
to be running correctly, dbgf works from iocsh, but caget from another
window on the same machine fails to connect.     I suspect it has something
to do with how the multiple interfaces on this machine are configured, but
so far have been unable to find a solution.
# ifconfig
eth0 Link encap:Ethernet HWaddr 00:1E:68:79:5C:4E inet addr:134.79.32.161 Bcast:134.79.35.255 Mask:255.255.252.0
         inet6 addr: fe80::21e:68ff:fe79:5c4e/64 Scope:Link
         UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
         RX packets:190759 errors:0 dropped:0 overruns:0 frame:0
         TX packets:43567 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:1000
         RX bytes:18427912 (17.5 MiB)  TX bytes:9772031 (9.3 MiB)
         Interrupt:19
eth2 Link encap:Ethernet HWaddr 00:1E:68:79:5C:50 inet addr:192.168.254.2 Bcast:192.168.254.255 Mask:255.255.255.0
         inet6 addr: fe80::21e:68ff:fe79:5c50/64 Scope:Link
         RX packets:1238443 errors:0 dropped:0 overruns:0 frame:0
         TX packets:879202 errors:0 dropped:0 overruns:0 carrier:0
         RX bytes:80539799 (76.8 MiB)  TX bytes:64420869 (61.4 MiB)
         Interrupt:20 Base address:0x4000
Gateway is 134.79.35.1
I'm running with defaults for the EPICS_CA* and EPICS_CAS* env variables,
but have also played with EPICS_CA_ADDR_LIST, EPICS_CA_AUTO_ADDR_LIST,
and EPICS_CA_INTF_ADDR_LIST with no success.
See attached files for casr, epicsEnvShow, ifconfig, and netstat output
for more configuration details. We're running base 3.14.9 everywhere, but this
is the only machine showing this problem.
The casr output includes:
UDP Server:
UDP 0.0.0.0:0(): User="", V4.0, 0 Channels, Priority=0
This looks wrong to me, as my working IOC's show a valid UDP addr, but I'm
not sure how to fix this, or even if this is the root problem.
Any suggestions would be appreciated.
- Bruce
P.S.  When I run caget, tcpdump shows:
# /usr/sbin/tcpdump -i eth0  -n -nn udp dst portrange 5064-5065
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes
21:46:55.934345 IP 192.168.254.2.54260 > 134.79.35.255.5065: UDP, length 16
21:46:57.179960 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.211939 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.275932 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.403935 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
          RX packets:169272 errors:0 dropped:0 overruns:0 frame:0
          TX packets:40902 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:16253702 (15.5 MiB)  TX bytes:9295274 (8.8 MiB)
          Interrupt:19
          RX packets:1183083 errors:0 dropped:0 overruns:0 frame:0
          TX packets:840829 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:76937113 (73.3 MiB)  TX bytes:61771629 (58.9 MiB)
eth3      Link encap:Ethernet  HWaddr 00:1E:68:79:5C:51
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 b)  TX bytes:0 (0.0 b)
          Interrupt:23 Base address:0x6000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:254294 errors:0 dropped:0 overruns:0 frame:0
          TX packets:254294 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:870404912 (830.0 MiB)  TX bytes:870404912 (830.0 MiB)
EDMOBJECTS=/reg/g/pcds/package/epics/3.14/extensions/current/templates/edm
EPICS_SITE_TOP=/reg/g/pcds/package/epics/3.14
HOSTNAME=bl13-ejb.slac.stanford.edu
GATEWAY_MODULE_VERSION=current
SHELL=/bin/bash
TERM=xterm
HISTSIZE=1000
EDMHELPFILES=/reg/g/pcds/package/epics/3.14/extensions/current/helpFiles
TST_SUBNET=42
BASE_MODULE_VERSION=current
EDMPVOBJECTS=/reg/g/pcds/package/epics/3.14/extensions/current/templates/edm
USER=rci
LD_LIBRARY_PATH=:/reg/g/pcds/package/epics/3.14/base/current/lib/linux-x86_64:/reg/g/pcds/package/epics/3.14/extensions/current/lib/linux-x86_64
LS_COLORS=no=00:fi=00:di=00;34:ln=00;36:pi=40;33:so=00;35:do=00;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=01;05;37;41:su=37;41:sg=30;43:tw=30;42:ow=34;42:st=37;44:ex=00;32:*.cmd=00;32:*.exe=00;32:*.com=00;32:*.btm=00;32:*.bat=00;32:*.sh=00;32:*.csh=00;32:*.tar=00;31:*.tgz=00;31:*.svgz=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.z=00;31:*.Z=00;31:*.dz=00;31:*.gz=00;31:*.bz2=00;31:*.tbz2=00;31:*.bz=00;31:*.tz=00;31:*.deb=00;31:*.rpm=00;31:*.jar=00;31:*.rar=00;31:*.ace=00;31:*.zoo=00;31:*.cpio=00;31:*.7z=00;31:*.rz=00;31:*.jpg=00;35:*.jpeg=00;35:*.gif=00;35:*.bmp=00;35:*.pbm=00;35:*.pgm=00;35:*.ppm=00;35:*.tga=00;35:*.xbm=00;35:*.xpm=00;35:*.tif=00;35:*.tiff=00;35:*.png=00;35:*.mng=00;35:*.pcx=00;35:*.mov=00;35:*.mpg=00;35:*.mpeg=00;35:*.m2v=00;35:*.mkv=00;35:*.ogm=00;35:*.mp4=00;35:*.m4v=00;35:*.mp4v=00;35:*.vob=00;35:*.qt=00;35:*.nuv=00;35:*.wmv=00;35:*.asf=00;35:*.rm=00;35:*.rmvb=00;35:*.flc=00;35:*.avi=00;35:*.fli=00;35:*.gl=00;35:*.dl=00;35:*.xcf=00;35:*.xwd=00;35:*.yuv=00;35:*.svg=00;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:
CDS_SUBNET=35
RUNUSER=/bin/bash -c
VDCT_CLASSPATH=/reg/g/pcds/package/epics/3.14/extensions/current/javalib/VisualDCT.jar
TOOLS_MODULE_VERSION=current
PROCSERV=/reg/g/pcds/package/procServ-2.4.0/procServ --allow --ignore ^D^C
MAIL=/var/spool/mail/rci
PATH=/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/reg/g/pcds/package/epics/3.14/base/current/bin/linux-x86_64:/reg/g/pcds/package/epics/3.14/tools/current/bin:/reg/g/pcds/package/epics/3.14/extensions/current/bin/linux-x86_64:/home/rci/bin
_=/reg/g/pcds/package/procServ-2.4.0/procServ
EDMLIBS=/reg/g/pcds/package/epics/3.14/extensions/current/lib/linux-x86_64
EDMFILES=/reg/g/pcds/package/epics/3.14/extensions/current/templates/edm
EPICS_SITE_CONFIG=/reg/g/pcds/package/epics/3.14/RELEASE_SITE
INPUTRC=/etc/inputrc
PWD=/reg/g/pcds/package/epics/3.14/ioc/sxr/rci/usbMotors/current/iocBoot/ioc-sxr-rci-usb
IOC_DATA=/reg/d/iocData/
SXR_SUBNET=39
MGT_SUBNET=24
LANG=en_US.UTF-8
SUBNET=32
XPP_SUBNET=38
EDMUSERLIB=/reg/g/pcds/package/epics/3.14/extensions/current/lib/linux-x86_64
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SHLVL=5
HOME=/home/rci
IOC=ioc-sxr-rci-usb
IOC_HOST=bl13-ejb
FEE_SUBNET=36
EXTENSIONS_MODULE_VERSION=current
EDMWEBBROWSER=mozilla
LOGNAME=rci
EPICS_TOOLS_SITE_TOP=/reg/g/pcds/package/epics/3.14
EDMFILTERS=/reg/g/pcds/package/epics/3.14/extensions/current/templates/edm
AMO_SUBNET=37
LESSOPEN=|/usr/bin/lesspipe.sh %s
CA_BIN=/reg/g/pcds/package/epics/3.14/base/current/bin/linux-x86_64
DISPLAY=localhost:11.0
IP=134.79.32.161
192.168.254.2
VDCT_MODULE_VERSION=current
G_BROKEN_FILENAMES=1
ENGINEER=Bruce Hill (bhill)
LOCATION=SXR:RCI:IOC:USB
IOCSH_PS1=ioc-sxr-rci-usb>
ARCH=linux-x86
TOP=/data/epics/3.14/ioc/sxr/rci/usbMotors/current
EPICS_MODULES=/reg/g/pcds/package/epics/3.14/modules
EPICS_BASE=/reg/g/pcds/package/epics/3.14/base/R3.14.9-0.3.0
AUTOSAVE=/reg/g/pcds/package/epics/3.14/modules/autosave/R4.2.1.2-1.1.0
IOCADMIN=/reg/g/pcds/package/epics/3.14/modules/iocAdmin/R2.0.0-1.1.0
ASYN=/reg/g/pcds/package/epics/3.14/modules/asyn/R4.10.1-1.0.0
MOTOR=/reg/g/pcds/package/epics/3.14/modules/motor/R6.4.4-1.7.0
EPICS_TS_NTP_INET=psntp.slac.stanford.edu
EPICS_IOC_LOG_PORT=7004
EPICS_IOC_LOG_INET=psloghost.slac.stanford.edu
EPICS_IOC_LOG_FILE_LIMIT=1000000
EPICS_IOC_LOG_FILE_COMMAND=
EPICS_CA_ADDR_LIST=
EPICS_CA_REPEATER_PORT=5065
EPICS_CA_SERVER_PORT=5064
EPICS_CA_CONN_TMO=10.0
EPICS_CA_BEACON_PERIOD=5.0
EPICS_CA_MAX_SEARCH_PERIOD=60.0
EPICS_CA_AUTO_ADDR_LIST=YES
EPICS_CAS_INTF_ADDR_LIST=
EPICS_CAS_BEACON_ADDR_LIST=
EPICS_CAS_AUTO_BEACON_ADDR_LIST=
EPICS_CAS_SERVER_PORT=
EPICS_CAS_BEACON_PORT=
EPICS_CAS_BEACON_PERIOD=5.0
EPICS_CA_MAX_ARRAY_BYTES=4000000
STREAM_PROTOCOL_PATH=protocol
LINES=24
COLUMNS=80
ioc-sxr-rci-usb> casr 2
Channel Access Server V4.11
No clients connected.
UDP Server:
        Task Id=0x8ea1e28, Socket FD=10
        Secs since last send 8225.52, Secs since last receive 8225.52
        Unprocessed request bytes=16, Undelivered response bytes=0
        State=up
        180 bytes allocated
There are currently 1260 bytes on the server's free list
7 client(s), 0 channel(s), 0 event(s) (monitors) 0 putNotify(s)
0 small buffers (16384 bytes ea), and 0 jumbo buffers (4000024 bytes ea)
The server's array size limit is 4000024 bytes max
Channel Access Address List
192.168.254.255:5065
134.79.35.255:5065
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address               Foreign Address             State
tcp        0      0 0.0.0.0:33632               0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:40001               0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:30050               0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:5064                0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:3306                0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:111                 0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:30000               0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:30001               0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:22                  0.0.0.0:*                   LISTEN
tcp        0      0 127.0.0.1:6010              0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:43931               0.0.0.0:*                   LISTEN
tcp        0      0 127.0.0.1:6011              0.0.0.0:*                   LISTEN
tcp        0      0 0.0.0.0:37916               0.0.0.0:*                   LISTEN
tcp        0      0 192.168.254.2:51042         192.168.254.101:2108        ESTABLISHED
tcp        0      0 192.168.254.2:38556         192.168.254.101:2104        ESTABLISHED
tcp        0      0 192.168.254.2:37630         192.168.254.101:2114        ESTABLISHED
tcp        0      0 192.168.254.2:37638         192.168.254.101:2109        ESTABLISHED
tcp        0      0 192.168.254.2:35860         192.168.254.101:2101        ESTABLISHED
tcp        0      0 192.168.254.2:34894         192.168.254.101:2105        ESTABLISHED
tcp        0      0 134.79.32.161:22            134.79.32.130:4002          ESTABLISHED
tcp        0      0 192.168.254.2:54953         192.168.254.101:2107        ESTABLISHED
tcp        0      0 192.168.254.2:55470         192.168.254.101:2112        ESTABLISHED
tcp        0      0 134.79.32.161:22            134.79.72.91:54486          ESTABLISHED
tcp        0      0 134.79.32.161:22            134.79.72.91:46773          ESTABLISHED
tcp        0      0 192.168.254.2:38144         192.168.254.101:2103        ESTABLISHED
tcp        0      0 192.168.254.2:45607         192.168.254.101:2102        ESTABLISHED
tcp        0      0 192.168.254.2:36498         192.168.254.101:2110        ESTABLISHED
tcp        0      0 192.168.254.2:45502         192.168.254.101:2106        ESTABLISHED
tcp        0      0 192.168.254.2:44382         192.168.254.101:2113        ESTABLISHED
tcp        0      0 :::45122                    :::*                        LISTEN
tcp        0      0 :::48905                    :::*                        LISTEN
tcp        0      0 ::ffff:127.0.0.1:33578      :::*                        LISTEN
tcp        0      0 :::3820                     :::*                        LISTEN
tcp        0      0 :::48974                    :::*                        LISTEN
tcp        0      0 :::8686                     :::*                        LISTEN
tcp        0      0 :::4848                     :::*                        LISTEN
tcp        0      0 :::8080                     :::*                        LISTEN
tcp        0      0 :::3920                     :::*                        LISTEN
tcp        0      0 :::3700                     :::*                        LISTEN
tcp        0      0 :::8181                     :::*                        LISTEN
tcp        0      0 :::22                       :::*                        LISTEN
tcp        0      0 :::40984                    :::*                        LISTEN
tcp        0      0 :::51288                    :::*                        LISTEN
tcp        0      0 ::1:6010                    :::*                        LISTEN
tcp        0      0 :::56762                    :::*                        LISTEN
tcp        0      0 ::1:6011                    :::*                        LISTEN
tcp        0      0 :::7676                     :::*                        LISTEN
tcp        0      0 ::ffff:134.79.32.161:47544  ::ffff:134.79.34.89:1000    ESTABLISHED
tcp        0      0 ::ffff:134.79.32.161:46212  ::ffff:134.79.34.89:1000    ESTABLISHED
tcp       40      0 ::ffff:192.168.254.2:58770  ::ffff:192.168.254.10:502   ESTABLISHED
tcp        0      0 ::ffff:192.168.254.2:58678  ::ffff:192.168.254.100:2104 ESTABLISHED
tcp        0      0 ::ffff:192.168.254.2:56091  ::ffff:192.168.254.100:2103 ESTABLISHED
tcp        0      0 ::ffff:134.79.32.161:50430  ::ffff:134.79.34.89:1000    ESTABLISHED
tcp        0      0 ::ffff:134.79.32.161:33522  ::ffff:134.79.34.89:1000    ESTABLISHED
tcp        0      0 ::ffff:192.168.254.2:35135  ::ffff:192.168.254.100:2102 ESTABLISHED
tcp        0      0 ::ffff:192.168.254.2:56779  ::ffff:192.168.254.100:2105 ESTABLISHED
udp        0      0 0.0.0.0:57221               0.0.0.0:*
udp        0      0 192.168.254.2:36998         134.79.35.255:5065          ESTABLISHED
udp        0      0 0.0.0.0:46476               0.0.0.0:*
udp        0      0 0.0.0.0:32909               0.0.0.0:*
udp        0      0 0.0.0.0:659                 0.0.0.0:*
udp        0      0 127.0.0.1:52124             127.0.0.1:34605             ESTABLISHED
udp        0      0 0.0.0.0:39198               0.0.0.0:*
udp        0      0 0.0.0.0:59173               0.0.0.0:*
udp        0      0 0.0.0.0:34605               0.0.0.0:*
udp        0      0 0.0.0.0:43694               0.0.0.0:*
udp        0      0 0.0.0.0:5064                0.0.0.0:*
udp        0      0 0.0.0.0:35016               0.0.0.0:*
udp        0      0 0.0.0.0:5065                0.0.0.0:*
udp        0      0 192.168.254.2:35918         134.79.35.255:5065          ESTABLISHED
udp        0      0 192.168.254.2:44379         0.0.0.0:*
udp        0      0 0.0.0.0:608                 0.0.0.0:*
udp        0      0 0.0.0.0:43493               0.0.0.0:*
udp        0      0 0.0.0.0:5353                0.0.0.0:*
udp        0      0 127.0.0.1:55277             127.0.0.1:43694             ESTABLISHED
udp        0      0 0.0.0.0:111                 0.0.0.0:*
udp        0      0 192.168.254.2:54260         134.79.35.255:5065          ESTABLISHED
udp        0      0 0.0.0.0:56565               0.0.0.0:*
udp        0      0 :::53263                    :::*
udp        0      0 :::41370                    :::*
udp        0      0 :::49819                    :::*
udp        0      0 :::45341                    :::*
udp        0      0 :::59043                    :::*
udp        0      0 :::60710                    :::*
udp        0      0 :::36401                    :::*
udp        0      0 :::41409                    :::*
udp        0      0 :::36420                    :::*
udp        0      0 :::44875                    :::*
udp        0      0 :::38366                    :::*
udp        0      0 :::54886                    :::*
udp        0      0 :::35184                    :::*
udp        0      0 :::52721                    :::*
udp        0      0 :::45682                    :::*
udp        0      0 :::40182                    :::*
udp        0      0 :::42234                    :::*
udp        0      0 :::56191                    :::*
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags       Type       State         I-Node Path
unix  2      [ ACC ]     STREAM     LISTENING     8197   @/var/run/hald/dbus-XPPhnxy7GD
unix  2      [ ACC ]     STREAM     LISTENING     7543   /var/run/audispd_events
unix  2      [ ACC ]     STREAM     LISTENING     7649   /var/run/rpcbind.sock
unix  2      [ ACC ]     STREAM     LISTENING     8055   /var/run/dbus/system_bus_socket
unix  2      [ ]         DGRAM                    1673   @/com/ubuntu/upstart
unix  2      [ ACC ]     STREAM     LISTENING     9072   /var/run/avahi-daemon/socket
unix  2      [ ACC ]     STREAM     LISTENING     9498   /tmp/.X11-unix/X0
unix  2      [ ACC ]     STREAM     LISTENING     12991  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  2      [ ACC ]     STREAM     LISTENING     8172   /var/run/acpid.socket
unix  2      [ ACC ]     STREAM     LISTENING     13000  /tmp/orbit-rci/linc-aac-0-3584d2b966200
unix  2      [ ACC ]     STREAM     LISTENING     13006  /tmp/keyring-8XGSLO/socket
unix  2      [ ACC ]     STREAM     LISTENING     13008  /tmp/keyring-8XGSLO/ssh
unix  2      [ ACC ]     STREAM     LISTENING     13010  /tmp/keyring-8XGSLO/socket.pkcs11
unix  2      [ ACC ]     STREAM     LISTENING     13074  /tmp/ssh-MVFtCb2738/agent.2738
unix  2      [ ACC ]     STREAM     LISTENING     13177  /tmp/orbit-rci/linc-ab2-0-6313415bafe9f
unix  2      [ ACC ]     STREAM     LISTENING     9497   @/tmp/.X11-unix/X0
unix  2      [ ACC ]     STREAM     LISTENING     13182  /tmp/.ICE-unix/2738
unix  2      [ ACC ]     STREAM     LISTENING     13208  /tmp/orbit-rci/linc-aeb-0-38fb5be1c67e3
unix  2      [ ACC ]     STREAM     LISTENING     9627   @/tmp/gdm-session-ZfztANUC
unix  2      [ ACC ]     STREAM     LISTENING     13920  /tmp/.esd-504/socket
unix  2      [ ACC ]     STREAM     LISTENING     13927  /tmp/pulse-rci/native
unix  2      [ ACC ]     STREAM     LISTENING     13954  /tmp/orbit-rci/linc-af0-0-291584f2dff14
unix  2      [ ]         DGRAM                    2038   @/org/kernel/udev/udevd
unix  2      [ ACC ]     STREAM     LISTENING     14191  /tmp/orbit-rci/linc-af8-0-2a9c73557117d
unix  2      [ ACC ]     STREAM     LISTENING     14310  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  2      [ ACC ]     STREAM     LISTENING     14316  /tmp/orbit-rci/linc-b03-0-646c1b0a4955
unix  2      [ ACC ]     STREAM     LISTENING     14401  /tmp/orbit-rci/linc-b07-0-2ea2d3f7bd3df
unix  2      [ ACC ]     STREAM     LISTENING     14406  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  2      [ ACC ]     STREAM     LISTENING     14695  /tmp/orbit-rci/linc-b0d-0-374d9efed4dcf
unix  2      [ ACC ]     STREAM     LISTENING     14790  /tmp/orbit-rci/linc-b13-0-7550bfade1198
unix  2      [ ACC ]     STREAM     LISTENING     15070  /tmp/orbit-rci/linc-b12-0-2ea2d3f6231fb
unix  2      [ ACC ]     STREAM     LISTENING     15128  /tmp/orbit-rci/linc-b2b-0-5cc9ebe33f113
unix  2      [ ACC ]     STREAM     LISTENING     15163  /tmp/orbit-rci/linc-b2c-0-5cc9ebe34d01c
unix  2      [ ACC ]     STREAM     LISTENING     15249  /tmp/orbit-rci/linc-b2e-0-7e6c12606a520
unix  2      [ ACC ]     STREAM     LISTENING     15584  /tmp/orbit-rci/linc-b50-0-73693cbd64bf
unix  2      [ ACC ]     STREAM     LISTENING     15590  /tmp/orbit-rci/linc-b4a-0-73693cbd6ab5
unix  2      [ ACC ]     STREAM     LISTENING     15594  /tmp/orbit-rci/linc-b4c-0-73693cbd6ed7
unix  2      [ ACC ]     STREAM     LISTENING     15673  /tmp/orbit-rci/linc-b4e-0-73693cbd36bae
unix  2      [ ACC ]     STREAM     LISTENING     15702  /tmp/orbit-rci/linc-b43-0-73693cbdf135b
unix  2      [ ACC ]     STREAM     LISTENING     8907   /var/run/setroubleshoot/setroubleshoot_server
unix  2      [ ACC ]     STREAM     LISTENING     15734  /tmp/orbit-rci/linc-b52-0-20ceddbcccfc9
unix  2      [ ACC ]     STREAM     LISTENING     15917  /tmp/orbit-rci/linc-b66-0-35df726feada2
unix  2      [ ACC ]     STREAM     LISTENING     8874   /var/lib/mysql/mysql.sock
unix  2      [ ]         DGRAM                    8242   @/org/freedesktop/hal/udev_event
unix  2      [ ACC ]     STREAM     LISTENING     48108  /tmp/ssh-YcYey16192/agent.16192
unix  2      [ ACC ]     STREAM     LISTENING     29941  /tmp/ssh-GlYymO8310/agent.8310
unix  2      [ ACC ]     STREAM     LISTENING     9628   @/tmp/gdm-greeter-crQfWFHp
unix  22     [ ]         DGRAM                    7601   /dev/log
unix  2      [ ACC ]     STREAM     LISTENING     13044  @/tmp/dbus-jJVdWdSUqd
unix  2      [ ACC ]     STREAM     LISTENING     8218   @/var/run/hald/dbus-LsXE5XPvHM
unix  2      [ ACC ]     STREAM     LISTENING     13181  @/tmp/.ICE-unix/2738
unix  3      [ ]         STREAM     CONNECTED     53187  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     53186
unix  2      [ ]         DGRAM                    51722
unix  2      [ ]         DGRAM                    51120
unix  2      [ ]         DGRAM                    48184
unix  2      [ ]         DGRAM                    48084
unix  3      [ ]         STREAM     CONNECTED     47694
unix  3      [ ]         STREAM     CONNECTED     47693
unix  2      [ ]         DGRAM                    47675
unix  3      [ ]         STREAM     CONNECTED     45980  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     45979
unix  2      [ ]         DGRAM                    43649
unix  2      [ ]         STREAM     CONNECTED     43368  /tmp/keyring-8XGSLO/socket
unix  2      [ ]         DGRAM                    30032
unix  2      [ ]         DGRAM                    29914
unix  3      [ ]         STREAM     CONNECTED     28279  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     28278
unix  2      [ ]         STREAM     CONNECTED     28169
unix  3      [ ]         STREAM     CONNECTED     28168  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     28167
unix  2      [ ]         STREAM     CONNECTED     17264
unix  2      [ ]         DGRAM                    16894
unix  3      [ ]         STREAM     CONNECTED     15933
unix  3      [ ]         STREAM     CONNECTED     15932
unix  3      [ ]         STREAM     CONNECTED     15931  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15930
unix  3      [ ]         STREAM     CONNECTED     15924  /tmp/orbit-rci/linc-b66-0-35df726feada2
unix  3      [ ]         STREAM     CONNECTED     15923
unix  3      [ ]         STREAM     CONNECTED     15922  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     15921
unix  3      [ ]         STREAM     CONNECTED     15920  /tmp/orbit-rci/linc-b66-0-35df726feada2
unix  3      [ ]         STREAM     CONNECTED     15919
unix  3      [ ]         STREAM     CONNECTED     15916  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15915
unix  3      [ ]         STREAM     CONNECTED     15914  /tmp/.ICE-unix/2738
unix  3      [ ]         STREAM     CONNECTED     15913
unix  3      [ ]         STREAM     CONNECTED     15908  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15907
unix  3      [ ]         STREAM     CONNECTED     15867  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15866
unix  3      [ ]         STREAM     CONNECTED     15865  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  3      [ ]         STREAM     CONNECTED     15864
unix  3      [ ]         STREAM     CONNECTED     15863  /tmp/orbit-rci/linc-b52-0-20ceddbcccfc9
unix  3      [ ]         STREAM     CONNECTED     15862
unix  3      [ ]         STREAM     CONNECTED     15861  /tmp/orbit-rci/linc-b52-0-20ceddbcccfc9
unix  3      [ ]         STREAM     CONNECTED     15860
unix  3      [ ]         STREAM     CONNECTED     15859  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     15858
unix  3      [ ]         STREAM     CONNECTED     15855  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15854
unix  3      [ ]         STREAM     CONNECTED     15851  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15850
unix  3      [ ]         STREAM     CONNECTED     15818  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15817
unix  3      [ ]         STREAM     CONNECTED     15816  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  3      [ ]         STREAM     CONNECTED     15815
unix  3      [ ]         STREAM     CONNECTED     15814  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15813
unix  3      [ ]         STREAM     CONNECTED     15781  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15780
unix  3      [ ]         STREAM     CONNECTED     15778  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15777
unix  3      [ ]         STREAM     CONNECTED     15779  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  3      [ ]         STREAM     CONNECTED     15776
unix  3      [ ]         STREAM     CONNECTED     15775  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15774
unix  3      [ ]         STREAM     CONNECTED     15773  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  3      [ ]         STREAM     CONNECTED     15772
unix  3      [ ]         STREAM     CONNECTED     15771  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15770
unix  3      [ ]         STREAM     CONNECTED     15755  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15754
unix  3      [ ]         STREAM     CONNECTED     15753  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15752
unix  3      [ ]         STREAM     CONNECTED     15737  /tmp/orbit-rci/linc-b52-0-20ceddbcccfc9
unix  3      [ ]         STREAM     CONNECTED     15736
unix  3      [ ]         STREAM     CONNECTED     15733  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15732
unix  3      [ ]         STREAM     CONNECTED     15731  /tmp/.ICE-unix/2738
unix  3      [ ]         STREAM     CONNECTED     15730
unix  3      [ ]         STREAM     CONNECTED     15724  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  3      [ ]         STREAM     CONNECTED     15723
unix  3      [ ]         STREAM     CONNECTED     15725  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15722
unix  3      [ ]         STREAM     CONNECTED     15721  /tmp/orbit-rci/linc-b4e-0-73693cbd36bae
unix  3      [ ]         STREAM     CONNECTED     15720
unix  3      [ ]         STREAM     CONNECTED     15719  /tmp/orbit-rci/linc-b4c-0-73693cbd6ed7
unix  3      [ ]         STREAM     CONNECTED     15717
unix  3      [ ]         STREAM     CONNECTED     15718  /tmp/orbit-rci/linc-b4a-0-73693cbd6ab5
unix  3      [ ]         STREAM     CONNECTED     15716
unix  3      [ ]         STREAM     CONNECTED     15715  /tmp/orbit-rci/linc-b50-0-73693cbd64bf
unix  3      [ ]         STREAM     CONNECTED     15714
unix  3      [ ]         STREAM     CONNECTED     15713  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15712
unix  3      [ ]         STREAM     CONNECTED     15707  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15706
unix  3      [ ]         STREAM     CONNECTED     15705  /tmp/orbit-rci/linc-b43-0-73693cbdf135b
unix  3      [ ]         STREAM     CONNECTED     15704
unix  3      [ ]         STREAM     CONNECTED     15701  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15700
unix  3      [ ]         STREAM     CONNECTED     15698  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15697
unix  3      [ ]         STREAM     CONNECTED     15696  /var/run/setroubleshoot/setroubleshoot_server
unix  3      [ ]         STREAM     CONNECTED     15695
unix  3      [ ]         STREAM     CONNECTED     15694  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15693
unix  3      [ ]         STREAM     CONNECTED     15682  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15681
unix  3      [ ]         STREAM     CONNECTED     15680  /tmp/orbit-rci/linc-b4e-0-73693cbd36bae
unix  3      [ ]         STREAM     CONNECTED     15679
unix  3      [ ]         STREAM     CONNECTED     15678  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     15677
unix  3      [ ]         STREAM     CONNECTED     15676  /tmp/orbit-rci/linc-b4e-0-73693cbd36bae
unix  3      [ ]         STREAM     CONNECTED     15675
unix  3      [ ]         STREAM     CONNECTED     15672  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15671
unix  3      [ ]         STREAM     CONNECTED     15663  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15662
unix  3      [ ]         STREAM     CONNECTED     15654  @/dbus-vfs-daemon/socket-2Ecvbxhb
unix  3      [ ]         STREAM     CONNECTED     15653
unix  3      [ ]         STREAM     CONNECTED     15655  @/dbus-vfs-daemon/socket-Jy4o6CFs
unix  3      [ ]         STREAM     CONNECTED     15652
unix  3      [ ]         STREAM     CONNECTED     15644  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15643
unix  3      [ ]         STREAM     CONNECTED     15642  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15641
unix  3      [ ]         STREAM     CONNECTED     15640  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15639
unix  3      [ ]         STREAM     CONNECTED     15638  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15637
unix  3      [ ]         STREAM     CONNECTED     15636  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15635
unix  3      [ ]         STREAM     CONNECTED     15634  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15633
unix  3      [ ]         STREAM     CONNECTED     15609  /tmp/orbit-rci/linc-b4c-0-73693cbd6ed7
unix  3      [ ]         STREAM     CONNECTED     15608
unix  3      [ ]         STREAM     CONNECTED     15607  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     15606
unix  3      [ ]         STREAM     CONNECTED     15605  /tmp/orbit-rci/linc-b4a-0-73693cbd6ab5
unix  3      [ ]         STREAM     CONNECTED     15604
unix  3      [ ]         STREAM     CONNECTED     15603  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     15602
unix  3      [ ]         STREAM     CONNECTED     15601  /tmp/orbit-rci/linc-b50-0-73693cbd64bf
unix  3      [ ]         STREAM     CONNECTED     15600
unix  3      [ ]         STREAM     CONNECTED     15599  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     15598
unix  3      [ ]         STREAM     CONNECTED     15597  /tmp/orbit-rci/linc-b4c-0-73693cbd6ed7
unix  3      [ ]         STREAM     CONNECTED     15596
unix  3      [ ]         STREAM     CONNECTED     15593  /tmp/orbit-rci/linc-b4a-0-73693cbd6ab5
unix  3      [ ]         STREAM     CONNECTED     15592
unix  3      [ ]         STREAM     CONNECTED     15589  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15588
unix  3      [ ]         STREAM     CONNECTED     15587  /tmp/orbit-rci/linc-b50-0-73693cbd64bf
unix  3      [ ]         STREAM     CONNECTED     15586
unix  3      [ ]         STREAM     CONNECTED     15583  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15582
unix  3      [ ]         STREAM     CONNECTED     15579  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15578
unix  3      [ ]         STREAM     CONNECTED     15573  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15572
unix  3      [ ]         STREAM     CONNECTED     15568  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15567
unix  3      [ ]         STREAM     CONNECTED     15566  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15565
unix  3      [ ]         STREAM     CONNECTED     15307  @/dbus-vfs-daemon/socket-EoSdv8tl
unix  3      [ ]         STREAM     CONNECTED     15305
unix  3      [ ]         STREAM     CONNECTED     15306  @/dbus-vfs-daemon/socket-wxiQqcnW
unix  3      [ ]         STREAM     CONNECTED     15304
unix  3      [ ]         STREAM     CONNECTED     15295  @/dbus-vfs-daemon/socket-MsxwgPfZ
unix  3      [ ]         STREAM     CONNECTED     15294
unix  3      [ ]         STREAM     CONNECTED     15296  @/dbus-vfs-daemon/socket-YTCTJRy2
unix  3      [ ]         STREAM     CONNECTED     15293
unix  3      [ ]         STREAM     CONNECTED     15290  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15289
unix  3      [ ]         STREAM     CONNECTED     15288  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15287
unix  2      [ ]         DGRAM                    15264
unix  3      [ ]         STREAM     CONNECTED     15263  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15262
unix  3      [ ]         STREAM     CONNECTED     15261  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  3      [ ]         STREAM     CONNECTED     15260
unix  3      [ ]         STREAM     CONNECTED     15257  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15256
unix  3      [ ]         STREAM     CONNECTED     15254  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15253
unix  3      [ ]         STREAM     CONNECTED     15252  /tmp/orbit-rci/linc-b2e-0-7e6c12606a520
unix  3      [ ]         STREAM     CONNECTED     15251
unix  3      [ ]         STREAM     CONNECTED     15248  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15247
unix  3      [ ]         STREAM     CONNECTED     15230  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  3      [ ]         STREAM     CONNECTED     15229
unix  3      [ ]         STREAM     CONNECTED     15226  /tmp/orbit-rci/linc-b2b-0-5cc9ebe33f113
unix  3      [ ]         STREAM     CONNECTED     15227  @/dbus-vfs-daemon/socket-vyFkI0KY
unix  3      [ ]         STREAM     CONNECTED     15225
unix  3      [ ]         STREAM     CONNECTED     15224
unix  3      [ ]         STREAM     CONNECTED     15228  @/dbus-vfs-daemon/socket-TohDlvGS
unix  3      [ ]         STREAM     CONNECTED     15223
unix  3      [ ]         STREAM     CONNECTED     15217  @/dbus-vfs-daemon/socket-SuaXxO7U
unix  3      [ ]         STREAM     CONNECTED     15216
unix  3      [ ]         STREAM     CONNECTED     15218  @/dbus-vfs-daemon/socket-Dg6oj7RH
unix  3      [ ]         STREAM     CONNECTED     15215
unix  3      [ ]         STREAM     CONNECTED     15204  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15201
unix  3      [ ]         STREAM     CONNECTED     15182  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     15181
unix  3      [ ]         STREAM     CONNECTED     15180  /tmp/orbit-rci/linc-b2c-0-5cc9ebe34d01c
unix  3      [ ]         STREAM     CONNECTED     15179
unix  3      [ ]         STREAM     CONNECTED     15173  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15172
unix  3      [ ]         STREAM     CONNECTED     15170  /tmp/orbit-rci/linc-b2c-0-5cc9ebe34d01c
unix  3      [ ]         STREAM     CONNECTED     15169
unix  3      [ ]         STREAM     CONNECTED     15168  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     15167
unix  3      [ ]         STREAM     CONNECTED     15166  /tmp/orbit-rci/linc-b2c-0-5cc9ebe34d01c
unix  3      [ ]         STREAM     CONNECTED     15165
unix  3      [ ]         STREAM     CONNECTED     15162  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15161
unix  3      [ ]         STREAM     CONNECTED     15141  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15140
unix  3      [ ]         STREAM     CONNECTED     15137  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15136
unix  3      [ ]         STREAM     CONNECTED     15135  /tmp/orbit-rci/linc-b2b-0-5cc9ebe33f113
unix  3      [ ]         STREAM     CONNECTED     15134
unix  3      [ ]         STREAM     CONNECTED     15133  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     15132
unix  3      [ ]         STREAM     CONNECTED     15131  /tmp/orbit-rci/linc-b2b-0-5cc9ebe33f113
unix  3      [ ]         STREAM     CONNECTED     15130
unix  3      [ ]         STREAM     CONNECTED     15114  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15112
unix  3      [ ]         STREAM     CONNECTED     15113  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15111
unix  3      [ ]         STREAM     CONNECTED     15104  /tmp/.ICE-unix/2738
unix  3      [ ]         STREAM     CONNECTED     15103
unix  3      [ ]         STREAM     CONNECTED     15101  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15100
unix  3      [ ]         STREAM     CONNECTED     15099  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15096
unix  3      [ ]         STREAM     CONNECTED     15092  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     15091
unix  3      [ ]         STREAM     CONNECTED     15089  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15088
unix  3      [ ]         STREAM     CONNECTED     15083  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     15082
unix  3      [ ]         STREAM     CONNECTED     15080  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15079
unix  3      [ ]         STREAM     CONNECTED     15078  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15077
unix  2      [ ]         DGRAM                    15076
unix  3      [ ]         STREAM     CONNECTED     15075  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15074
unix  3      [ ]         STREAM     CONNECTED     15073  /tmp/orbit-rci/linc-b12-0-2ea2d3f6231fb
unix  3      [ ]         STREAM     CONNECTED     15072
unix  3      [ ]         STREAM     CONNECTED     15069  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     15067
unix  3      [ ]         STREAM     CONNECTED     15066  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     15065
unix  3      [ ]         STREAM     CONNECTED     14907  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     14906
unix  3      [ ]         STREAM     CONNECTED     14828  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     14825
unix  3      [ ]         STREAM     CONNECTED     14815  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     14814
unix  3      [ ]         STREAM     CONNECTED     14800  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     14797
unix  3      [ ]         STREAM     CONNECTED     14795  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     14794
unix  3      [ ]         STREAM     CONNECTED     14793  /tmp/orbit-rci/linc-b13-0-7550bfade1198
unix  3      [ ]         STREAM     CONNECTED     14792
unix  3      [ ]         STREAM     CONNECTED     14760  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     14756
unix  3      [ ]         STREAM     CONNECTED     14753  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     14752
unix  3      [ ]         STREAM     CONNECTED     14748  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     14747
unix  3      [ ]         STREAM     CONNECTED     14746  /tmp/orbit-rci/linc-b07-0-2ea2d3f7bd3df
unix  3      [ ]         STREAM     CONNECTED     14745
unix  3      [ ]         STREAM     CONNECTED     14744  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     14743
unix  3      [ ]         STREAM     CONNECTED     15031  /tmp/.ICE-unix/2738
unix  3      [ ]         STREAM     CONNECTED     14742
unix  3      [ ]         STREAM     CONNECTED     14700  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     14699
unix  3      [ ]         STREAM     CONNECTED     14698  /tmp/orbit-rci/linc-b0d-0-374d9efed4dcf
unix  3      [ ]         STREAM     CONNECTED     14697
unix  3      [ ]         STREAM     CONNECTED     14694  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     14693
unix  3      [ ]         STREAM     CONNECTED     14689  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     14688
unix  3      [ ]         STREAM     CONNECTED     14687  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     14686
unix  3      [ ]         STREAM     CONNECTED     14683  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     14682
unix  3      [ ]         STREAM     CONNECTED     14616  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     14614
unix  3      [ ]         STREAM     CONNECTED     14609  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     14608
unix  3      [ ]         STREAM     CONNECTED     14444  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  3      [ ]         STREAM     CONNECTED     14443
unix  3      [ ]         STREAM     CONNECTED     14412  /tmp/orbit-rci/linc-b0b-0-1036e78fbf09c
unix  3      [ ]         STREAM     CONNECTED     14410
unix  3      [ ]         STREAM     CONNECTED     14411  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     14408
unix  3      [ ]         STREAM     CONNECTED     14404  /tmp/orbit-rci/linc-b07-0-2ea2d3f7bd3df
unix  3      [ ]         STREAM     CONNECTED     14403
unix  3      [ ]         STREAM     CONNECTED     14400  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     14399
unix  3      [ ]         STREAM     CONNECTED     14368  /tmp/.ICE-unix/2738
unix  3      [ ]         STREAM     CONNECTED     14367
unix  3      [ ]         STREAM     CONNECTED     14362  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     14361
unix  3      [ ]         STREAM     CONNECTED     14358  /tmp/.ICE-unix/2738
unix  3      [ ]         STREAM     CONNECTED     14357
unix  3      [ ]         STREAM     CONNECTED     14319  /tmp/orbit-rci/linc-b03-0-646c1b0a4955
unix  3      [ ]         STREAM     CONNECTED     14318
unix  3      [ ]         STREAM     CONNECTED     14315  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     14314
unix  3      [ ]         STREAM     CONNECTED     14313  /tmp/orbit-rci/linc-b05-0-2ea2d3f7a45e4
unix  3      [ ]         STREAM     CONNECTED     14312
unix  3      [ ]         STREAM     CONNECTED     14309  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     14308
unix  3      [ ]         STREAM     CONNECTED     14304  /tmp/.ICE-unix/2738
unix  3      [ ]         STREAM     CONNECTED     14303
unix  3      [ ]         STREAM     CONNECTED     14299  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     14297
unix  3      [ ]         STREAM     CONNECTED     14296  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     14295
unix  3      [ ]         STREAM     CONNECTED     14284  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     14282
unix  3      [ ]         STREAM     CONNECTED     14198  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     14197
unix  3      [ ]         STREAM     CONNECTED     14196  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     14195
unix  3      [ ]         STREAM     CONNECTED     14194  /tmp/orbit-rci/linc-af8-0-2a9c73557117d
unix  3      [ ]         STREAM     CONNECTED     14193
unix  3      [ ]         STREAM     CONNECTED     14190  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     14189
unix  3      [ ]         STREAM     CONNECTED     14185  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     14184
unix  3      [ ]         STREAM     CONNECTED     13959  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     13958
unix  3      [ ]         STREAM     CONNECTED     13957  /tmp/orbit-rci/linc-af0-0-291584f2dff14
unix  3      [ ]         STREAM     CONNECTED     13956
unix  3      [ ]         STREAM     CONNECTED     13953  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     13952
unix  3      [ ]         STREAM     CONNECTED     13966  /tmp/.esd-504/socket
unix  3      [ ]         STREAM     CONNECTED     13925
unix  3      [ ]         STREAM     CONNECTED     13886  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     13881
unix  3      [ ]         STREAM     CONNECTED     13385  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     13384
unix  3      [ ]         STREAM     CONNECTED     13211  /tmp/orbit-rci/linc-aeb-0-38fb5be1c67e3
unix  3      [ ]         STREAM     CONNECTED     13210
unix  3      [ ]         STREAM     CONNECTED     13207  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     13206
unix  3      [ ]         STREAM     CONNECTED     13202  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     13201
unix  3      [ ]         STREAM     CONNECTED     13199  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     13198
unix  3      [ ]         STREAM     CONNECTED     13190  @/tmp/dbus-jJVdWdSUqd
unix  3      [ ]         STREAM     CONNECTED     13189
unix  3      [ ]         STREAM     CONNECTED     13180  /tmp/orbit-rci/linc-ab2-0-6313415bafe9f
unix  3      [ ]         STREAM     CONNECTED     13179
unix  3      [ ]         STREAM     CONNECTED     13176  /tmp/orbit-rci/linc-aaf-0-6b4eedae6111e
unix  3      [ ]         STREAM     CONNECTED     13175
unix  3      [ ]         STREAM     CONNECTED     13148  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     13147
unix  3      [ ]         STREAM     CONNECTED     13057  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     13056
unix  3      [ ]         STREAM     CONNECTED     13054
unix  3      [ ]         STREAM     CONNECTED     13053
unix  4      [ ]         STREAM     CONNECTED     13029  @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     13028
unix  2      [ ]         DGRAM                    13017
unix  3      [ ]         STREAM     CONNECTED     13014  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     13013
unix  2      [ ]         DGRAM                    12986
unix  3      [ ]         STREAM     CONNECTED     12892  /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     12891
unix  3      [ ]         STREAM     CONNECTED     10063  @/tmp/gdm-session-ZfztANUC
unix  3      [ ]         STREAM     CONNECTED     10062
unix  3      [ ]         STREAM     CONNECTED     9681   @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     9680
unix  3      [ ]         STREAM     CONNECTED     9677   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     9676
unix  5      [ ]         STREAM     CONNECTED     9650   @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     9649
unix  5      [ ]         STREAM     CONNECTED     9586   @/tmp/.X11-unix/X0
unix  3      [ ]         STREAM     CONNECTED     9585
unix  3      [ ]         STREAM     CONNECTED     9582   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     9581
unix  3      [ ]         STREAM     CONNECTED     9502   /var/run/acpid.socket
unix  3      [ ]         STREAM     CONNECTED     9501
unix  3      [ ]         STREAM     CONNECTED     9481   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     9480
unix  3      [ ]         STREAM     CONNECTED     9458   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     9457
unix  3      [ ]         STREAM     CONNECTED     9075   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     9074
unix  3      [ ]         STREAM     CONNECTED     9069
unix  3      [ ]         STREAM     CONNECTED     9068
unix  2      [ ]         DGRAM                    9066
unix  3      [ ]         STREAM     CONNECTED     8972   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8971
unix  2      [ ]         DGRAM                    8915
unix  3      [ ]         STREAM     CONNECTED     8911   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8910
unix  3      [ ]         STREAM     CONNECTED     8906   /var/run/audispd_events
unix  3      [ ]         STREAM     CONNECTED     8905
unix  2      [ ]         DGRAM                    8728
unix  2      [ ]         DGRAM                    8725
unix  3      [ ]         STREAM     CONNECTED     8724   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8723
unix  3      [ ]         STREAM     CONNECTED     8720   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8719
unix  3      [ ]         STREAM     CONNECTED     8636   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8635
unix  2      [ ]         DGRAM                    8632
unix  3      [ ]         STREAM     CONNECTED     8422   @/var/run/hald/dbus-XPPhnxy7GD
unix  3      [ ]         STREAM     CONNECTED     8421
unix  3      [ ]         STREAM     CONNECTED     8418   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8417
unix  3      [ ]         STREAM     CONNECTED     8394   /var/run/acpid.socket
unix  3      [ ]         STREAM     CONNECTED     8393
unix  3      [ ]         STREAM     CONNECTED     8388   @/var/run/hald/dbus-XPPhnxy7GD
unix  3      [ ]         STREAM     CONNECTED     8387
unix  3      [ ]         STREAM     CONNECTED     8346   @/var/run/hald/dbus-XPPhnxy7GD
unix  3      [ ]         STREAM     CONNECTED     8325
unix  3      [ ]         STREAM     CONNECTED     8237   @/var/run/hald/dbus-LsXE5XPvHM
unix  3      [ ]         STREAM     CONNECTED     8236
unix  3      [ ]         STREAM     CONNECTED     8215   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8214
unix  3      [ ]         STREAM     CONNECTED     8199   /var/run/dbus/system_bus_socket
unix  3      [ ]         STREAM     CONNECTED     8198
unix  2      [ ]         DGRAM                    8174
unix  3      [ ]         STREAM     CONNECTED     8068
unix  3      [ ]         STREAM     CONNECTED     8067
unix  3      [ ]         STREAM     CONNECTED     8012
unix  3      [ ]         STREAM     CONNECTED     8011
unix  2      [ ]         DGRAM                    7703
unix  3      [ ]         STREAM     CONNECTED     7537
unix  3      [ ]         STREAM     CONNECTED     7536
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
192.168.254.0   0.0.0.0         255.255.255.0   U         0 0          0 eth2
134.79.32.0     0.0.0.0         255.255.252.0   U         0 0          0 eth0
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 eth2
0.0.0.0         134.79.35.1     0.0.0.0         UG        0 0          0 eth0
Re: Channel Access not connecting Maren Purves
RE: Channel Access not connecting Mark Rivers
Re: Channel Access not connecting Claude Saunders
Prev: RE: EPICS support for OMRON PLC SYSMAC CJIM CPU12-ETN Ethernet communications? CryoCon RS-232? Jay Steele
Next: Re: Channel Access not connecting Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Announce: seq-2.0.14 Benjamin Franksen
