1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access not connecting
To: Bruce Hill <[email protected]>
Cc: Techtalk <[email protected]>
Date: Mon, 16 May 2011 21:40:57 -1000 (HST)
Hi Bruce,
as I'm just finding this logging in from home:
I'm probably way off but this reminds me of the ARP cache
problems we used to sometimes have years ago when switching
machines/IOC boards. You may be able to do something
with address lists, apart from that my memory is really
fuzzy about it. You may be able to find something searching
the tech-talk archives for 'ARP cache' - but it may have to
do with your dual interface and the gateway.
Hope this helps any at all,
Aloha,
Maren
On Mon, 16 May 2011, Bruce Hill wrote:
I've been having trouble with one linux machine where my IOC's appear
to be running correctly, dbgf works from iocsh, but caget from another
window on the same machine fails to connect.     I suspect it has something
to do with how the multiple interfaces on this machine are configured, but
so far have been unable to find a solution.
# ifconfig
eth0 Link encap:Ethernet HWaddr 00:1E:68:79:5C:4E inet addr:134.79.32.161 Bcast:134.79.35.255 Mask:255.255.252.0
        inet6 addr: fe80::21e:68ff:fe79:5c4e/64 Scope:Link
        UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
        RX packets:190759 errors:0 dropped:0 overruns:0 frame:0
        TX packets:43567 errors:0 dropped:0 overruns:0 carrier:0
        collisions:0 txqueuelen:1000
        RX bytes:18427912 (17.5 MiB)  TX bytes:9772031 (9.3 MiB)
        Interrupt:19
eth2 Link encap:Ethernet HWaddr 00:1E:68:79:5C:50 inet addr:192.168.254.2 Bcast:192.168.254.255 Mask:255.255.255.0
        inet6 addr: fe80::21e:68ff:fe79:5c50/64 Scope:Link
        RX packets:1238443 errors:0 dropped:0 overruns:0 frame:0
        TX packets:879202 errors:0 dropped:0 overruns:0 carrier:0
        RX bytes:80539799 (76.8 MiB)  TX bytes:64420869 (61.4 MiB)
        Interrupt:20 Base address:0x4000
Gateway is 134.79.35.1
I'm running with defaults for the EPICS_CA* and EPICS_CAS* env variables,
but have also played with EPICS_CA_ADDR_LIST, EPICS_CA_AUTO_ADDR_LIST,
and EPICS_CA_INTF_ADDR_LIST with no success.
See attached files for casr, epicsEnvShow, ifconfig, and netstat output
for more configuration details. We're running base 3.14.9 everywhere, but this
is the only machine showing this problem.
The casr output includes:
UDP Server:
UDP 0.0.0.0:0(): User="", V4.0, 0 Channels, Priority=0
This looks wrong to me, as my working IOC's show a valid UDP addr, but I'm
not sure how to fix this, or even if this is the root problem.
Any suggestions would be appreciated.
- Bruce
P.S.  When I run caget, tcpdump shows:
# /usr/sbin/tcpdump -i eth0  -n -nn udp dst portrange 5064-5065
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes
21:46:55.934345 IP 192.168.254.2.54260 > 134.79.35.255.5065: UDP, length 16
21:46:57.179960 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.211939 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.275932 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
21:46:57.403935 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP, length 48
Channel Access not connecting Bruce Hill
Prev: Channel Access not connecting Bruce Hill
Next: RE: Channel Access not connecting Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
