1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: TCP_NODELAY option set failed
Cc: "Chabot, Daron" <[email protected]>
Date: Tue, 17 May 2011 10:55:01 -0400
Cexp>
Cexp>CAS: TCP_NODELAY option set failed
I happened to notice this error in the log of one of our IOCs. I've not seen it before. It only happened once, but seemed suitable strange to be worth reporting.
EPICS 3.14.11
RTEMS 4.9.3 on a mvme3100
Also deviocstats and the new mrfioc2 timing driver. The IOC was functioning correctly when I checked it.
It looks like this error comes from create_tcp_client() in caservertask.c when setsockopt() for the NODELAY socket option fails for a newly connected CA client. Since I only see one message I assume the client was able to connect successfully on a retry.
Has anyone else seen this error?
Michael
RE: TCP_NODELAY option set failed Jeff Hill
Prev: Re: Channel Access not connecting Claude Saunders
Next: RE: Channel Access not connecting Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Channel Access not connecting Jeff Hill
Next: RE: TCP_NODELAY option set failed Jeff Hill
