1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Channel Access not connecting
To: "'Claude Saunders'" <[email protected]>, <[email protected]>
Date: Tue, 17 May 2011 09:05:57 -0600
> I gather with linux, the network stack will only
> deliver an incoming (pv search) broadcast UDP packet to one of those
> processes.
You will see a warning message about the issue when you start the 2nd IOC.
As a workaround, a unicast (a single host IP) in the EPICS_CA_ADDR_LIST will
connect.
PS: The new multicasting support will provide a nice solution for this
issue.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Claude Saunders
> Sent: Tuesday, May 17, 2011 8:02 AM
> To: [email protected]
> Subject: Re: Channel Access not connecting
> Hi Bruce,
>  From your first sentence, I see "IOC's" (plural) and "linux". I
> recently had what I believe is the same problem, which Andrew Johnson
> kindly helped me understand. If you are running two iocs on one linux
> host, using default ports, you wind up with two processes listening on
> the same udp port. I gather with linux, the network stack will only
> processes. If it happens to be the one without the PV you're looking
> for, then the ca_search fails, even though the other IOC process
> contains the PV.
>     - Claude
> On 05/17/2011 12:12 AM, Bruce Hill wrote:
> > I've been having trouble with one linux machine where my IOC's appear
> > to be running correctly, dbgf works from iocsh, but caget from another
> > window on the same machine fails to connect.     I suspect it has
> > something
> > to do with how the multiple interfaces on this machine are configured,
> > but
> > so far have been unable to find a solution.
> > # ifconfig
> > eth0      Link encap:Ethernet  HWaddr 00:1E:68:79:5C:4E          inet
> > addr:134.79.32.161  Bcast:134.79.35.255  Mask:255.255.252.0
> >          inet6 addr: fe80::21e:68ff:fe79:5c4e/64 Scope:Link
> >          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
> >          RX packets:190759 errors:0 dropped:0 overruns:0 frame:0
> >          TX packets:43567 errors:0 dropped:0 overruns:0 carrier:0
> >          collisions:0 txqueuelen:1000
> >          RX bytes:18427912 (17.5 MiB)  TX bytes:9772031 (9.3 MiB)
> >          Interrupt:19
> > eth2      Link encap:Ethernet  HWaddr 00:1E:68:79:5C:50          inet
> > addr:192.168.254.2  Bcast:192.168.254.255  Mask:255.255.255.0
> >          inet6 addr: fe80::21e:68ff:fe79:5c50/64 Scope:Link
> >          RX packets:1238443 errors:0 dropped:0 overruns:0 frame:0
> >          TX packets:879202 errors:0 dropped:0 overruns:0 carrier:0
> >          RX bytes:80539799 (76.8 MiB)  TX bytes:64420869 (61.4 MiB)
> >          Interrupt:20 Base address:0x4000
> > Gateway is 134.79.35.1
> > I'm running with defaults for the EPICS_CA* and EPICS_CAS* env
> variables,
> > but have also played with EPICS_CA_ADDR_LIST, EPICS_CA_AUTO_ADDR_LIST,
> > and EPICS_CA_INTF_ADDR_LIST with no success.
> > See attached files for casr, epicsEnvShow, ifconfig, and netstat output
> > for more configuration details.     We're running base 3.14.9
> > everywhere, but this
> > is the only machine showing this problem.
> > The casr output includes:
> > UDP Server:
> > UDP 0.0.0.0:0(): User="", V4.0, 0 Channels, Priority=0
> > This looks wrong to me, as my working IOC's show a valid UDP addr, but
> > I'm
> > not sure how to fix this, or even if this is the root problem.
> > Any suggestions would be appreciated.
> > Thanks,
> > - Bruce
> > P.S.  When I run caget, tcpdump shows:
> > # /usr/sbin/tcpdump -i eth0  -n -nn udp dst portrange 5064-5065
> > tcpdump: verbose output suppressed, use -v or -vv for full protocol
> > decode
> > listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes
> > 21:46:55.934345 IP 192.168.254.2.54260 > 134.79.35.255.5065: UDP,
> > length 16
> > 21:46:57.179960 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP,
> > length 48
> > 21:46:57.211939 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP,
> > length 48
> > 21:46:57.275932 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP,
> > length 48
> > 21:46:57.403935 IP 134.79.32.161.43268 > 134.79.35.255.5064: UDP,
> > length 48
>   Claude Saunders<[email protected]>
>   Software Services Group Leader
>   Advanced Photon Source,   Argonne National Laboratory
>   Argonne, IL  60439                   630 - 252 - 6619
>      We write suggestions, suggesting fading to silence
>      And that must please you
>      My mirror's tarnished with 'no help'
>                        - Gary Numan
Channel Access not connecting Bruce Hill
Re: Channel Access not connecting Claude Saunders
Prev: TCP_NODELAY option set failed Michael Davidsaver
Next: RE: Channel Access not connecting Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Access not connecting Bruce Hill
Next: TCP_NODELAY option set failed Michael Davidsaver
