1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: alh1_2_24 build problem
To: Noel Giffin <[email protected]>
Cc: [email protected]
Date: Wed, 18 May 2011 10:09:11 -0500
Hi Noel,
On 2011-05-17 Noel Giffin wrote:
> Could not build latest ALH version alh1_2_24 due to undeclared boolean YES
>  in force.c
There are actually a couple of newer releases of ALH than that, at least one
of which does include this change, but unfortunately they hadn't made it onto
the download/extensions page yet (they were available from the extensions/alh
page though).  There appears to be an even newer release 1.2.27 in CVS, but
apparently Janet hasn't published the tarfile for that yet; you can see the
changes between releases in the CVS Web Browser at
    http://www.aps.anl.gov/cgi-bin/epics/cvsweb/extensions/src/alh/
and download the latest committed version using the snapshot file.
Sorry about the misleading download/extensions page; I've just updated it with
all of the latest files.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
alh1_2_24 build problem Noel Giffin
Prev: Re: caGateway crashes / use of *MustSucceed functions J. Lewis Muir
Next: Re: caGateway crashes / use of *MustSucceed functions Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: alh1_2_24 build problem Noel Giffin
Next: caGateway crashes / use of *MustSucceed functions Dirk Zimoch
