1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: alh1_2_24 build problem
To: EPICS Tech Talk <[email protected]>
Date: Tue, 17 May 2011 12:48:22 -0700
Could not build latest ALH version alh1_2_24 due to undeclared boolean YES in force.c
building epics extensions for epics 3.14.12.1-rc1 and ran into trouble building ALH1_2_24 using standard Makefile.
Environment is:
Sci. Linux 5.5
epics base 3.14.12.1-rc1
gcc (GCC) 4.1.2 20080704 (Red Hat 4.1.2-50)
build fails reporting:
../force.c: In function ?forcePVUpdateFields?:
../force.c:1028: error: ?YES? undeclared (first use in this function)
../force.c:1028: error: (Each undeclared identifier is reported only once
../force.c:1028: error: for each function it appears in.)
make[1]: *** [force.o] Error 1
make[1]: Leaving directory `/usr1/epics/extensions/src/alh1_2_24/O.linux-x86'
make: *** [install.linux-x86] Error 2
Added declarations for YES NO in force.c and build was successful.
Re: alh1_2_24 build problem Andrew Johnson
Prev: RE: Simple VME digital I/O Mark Rivers
Next: Re: Channel Access not connecting Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: alh1_2_24 build problem Andrew Johnson
