1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem building 3.14.12.1 on cygwin-x86
To: "Janet Anderson" <[email protected]>
Date: Fri, 20 May 2011 17:41:58 -0500
Hi Janet,
I’m having trouble building "antelope" on cygwin-x86 under 3.14.12.1.  It works fine under 3.14.12.
Here is the output of the final link command under 3.14.12
$ make
g++ -o antelope.exe -static -Lh:/epics/base-3.14.12/lib/cygwin-x86       -m32                closure.o error.o lalr.o lr0.o main.o mkpar.o o
utput.o reader.o skeleton.o symtab.o verbose.o warshall.o   -lCom   -lpthread   -lreadline -lcurses -lm
Installing created file ../../../../bin/cygwin-x86/antelope.exe
make[1]: Leaving directory `/cygdrive/h/epics/base-3.14.12/src/toolsComm/antelope/O.cygwin-x86'
Here is the output under 3.14.12.1
g++ -o antelope.exe -static -Lh\:/epics/base-3.14.12.1/lib/cygwin-x86       -m32                closure.o error.o lalr.o lr0.o main.o mkpar.
o output.o reader.o skeleton.o symtab.o verbose.o warshall.o   -lCom   -lpthread   -lreadline -lcurses -lm
/usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin/bin/ld: cannot find -lCom
collect2: ld returned 1 exit status
make[1]: *** [antelope.exe] Error 1
make[1]: Leaving directory `/cygdrive/h/epics/base-3.14.12.1/src/toolsComm/antelope/O.cygwin-x86'
make: *** [install.cygwin-x86] Error 2
The difference is that under 3.14.12 the command produced has “-Lh:/epics/base-3.14.12/lib/cygwin-x86”, while under 3.14.12.1 it has “-Lh\:/epics/base-3.14.12.1/lib/cygwin-x86”, i.e. it has an extra backslash.
I am compiling this under the Cygwin bash shell.
The cygwin configuation files in configure/os are identical in the 3.14.12 and 3.14.12.1 directories.
Prev: RE: problem with gateway and softIoc running on same server Kevin Tsubota
Next: CAJ Flow Control Bug David Brodrick
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: trouble with 64-bit Window7 Mark Rivers
