1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: caGateway crashes / use of *MustSucceed functions
To: "'Dirk Zimoch'" <[email protected]>
Cc: "'EPICS Tech Talk'" <[email protected]>
Date: Mon, 23 May 2011 09:57:11 -0600
> This show why C++ exceptions are better than the good old C abort().
(100% agreement from here :-)
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: Dirk Zimoch [mailto:[email protected]]
> Sent: Monday, May 23, 2011 2:18 AM
> To: Jeff Hill
> Cc: 'EPICS Tech Talk'
> Subject: Re: caGateway crashes / use of *MustSucceed functions
> > [...] One exception frequently cited is when
> > starting an IOC its maybe ok, but if this occurs in common library code
> then
> > it's probably going to be used inappropriately in other situations, and
> > surely eventually we will need to upgrade allowing online add and delete
> of
> > records and then it's less clear when iocInit starts and ends?
> This show why C++ exceptions are better than the good old C abort(). If
> creation of a new record fails because of insufficient memory, an
> exception can be thrown. During run-time it should be caught and an
> error should be reported to the user that the record can't be added to
> the system. During initialization, it may be acceptable not to catch the
> exception which will in the end call abort(). Thus the application
> developer and not the support library developer decides if the
> application (here the ioc) must die or not.
> By the way, if creation of a record fails because of a typo in a
> template file, the ioc happily continues starting up, but with one or
> many records missing -- even though this *is* a programming error, not a
> run-time problem.
> Dirk
caGateway crashes / use of *MustSucceed functions Dirk Zimoch
Re: caGateway crashes / use of *MustSucceed functions J. Lewis Muir
Re: caGateway crashes / use of *MustSucceed functions Dirk Zimoch
RE: caGateway crashes / use of *MustSucceed functions Jeff Hill
Prev: RE: vxWorks network problems Jeff Hill
Next: Re: When a record is changed twice very fast, camonitor only detects first change Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caGateway crashes / use of *MustSucceed functions Benjamin Franksen
Next: Re: caGateway crashes / use of *MustSucceed functions Jim Thomas
