1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Windows XP Cygwin difficulties for building EPICS base
To: "'[email protected]'" <[email protected]>
Date: Mon, 23 May 2011 16:52:53 -0700
I’m a beginner with EPICS.
I’m trying to build EPICS base (3.14.12.1) on Windows XP with Cygwin (EPICS_HOST_ARCH = cygwin-x86, SHARED_LIBRARIES = NO, STATIC_BUILD = YES).   I get pretty far into the build, but encounter the following error for  directory src/cap5 (see below).
make[3]: Leaving directory `/cygdrive/c/EPICS/base/src/excas/O.cygwin-x86'
make[2]: Leaving directory `/cygdrive/c/EPICS/base/src/excas'
make -C ./cap5 install
make[2]: Entering directory `/cygdrive/c/EPICS/base/src/cap5'
perl ../../bin/cygwin-x86/makeMakefile.pl O.cygwin-x86 ../../..
mkdir O.Common
make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering directory `/cygdrive/c/EPICS/base/src/cap5/O.cygwin-x86'
rm -f CA.html
podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
/bin/sh: /usr/bin/podchecker: /usr/bin/perl: bad interpreter: No such file or di
rectory
make[3]: *** [CA.html] Error 126
make[3]: Leaving directory `/cygdrive/c/EPICS/base/src/cap5/O.cygwin-x86'
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory `/cygdrive/c/EPICS/base/src/cap5'
make[1]: *** [cap5.install] Error 2
make[1]: Leaving directory `/cygdrive/c/EPICS/base/src'
make: *** [src.install] Error 2
Any help/assistance will be greatly appreciated.
Thanks in advance,
Florencio Cid
Re: Windows XP Cygwin difficulties for building EPICS base Dirk Zimoch
Re: Windows XP Cygwin difficulties for building EPICS base Andrew Johnson
Prev: Re: vxWorks network problems Andrew Johnson
Next: Device Support for Nemic Lambda Power Supplies Anthony Andrews
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: When a record is changed twice very fast, camonitor only detects first change Andrew Johnson
Next: Re: Windows XP Cygwin difficulties for building EPICS base Dirk Zimoch
