Hi Mikel,
On 2011-05-23 Mikel Rojo wrote:
> I don't understand how camonitor can say that a pv has one value, while
> with caget we can see that it has a different one. I tried stopping the
> monitor before clearing the variable and then starting the monitor again
> afterwards but it does not change anything. I am using the latest
> version of base (3.14.12.1) and sequencer (2.0.13). I would really
> appreciate any help. Thank you in advance.
In addition to the comments Matthieu made about your pvGet() being unnecessary
and possibly even harmful, I recommend that you never change the value or use
pvPut() on a variable that has a monitor set on it. There is a known race
condition in the sequencer such that a monitor event can arrive and change a
variable's value while the sequencer is still processing the action statements
from a previous state transition. If you want to update the value of a PV
that you're monitoring, create a second variable assigned to the same PV and
use that variable for all pvPut() operations. Your code also needs to allow
for the fact that the pvPut() can cause another monitor to be queued and thus
set your event flag again.
There is another issue that you might also be hitting, although I don't think
so in this case: A ca_monitor() of a string PV that changes often is not
guaranteed to always send the actual character string that caused the monitor,
it might skip one or more values from a very busy record. Here's why:
When a record processes and triggers a monitor, the code pushes an event
object onto the send queue for each client, but to save memory we don't copy
string or array values into that object (it only has enough space for scalars
up to size double). When the client's send thread later executes to forward
that value it will lock the record and copy the string value out of the record
field into the TCP socket buffer, but if the record has processed since the
original value was queued it will be given the newer string instead.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- When a record is changed twice very fast, camonitor only detects first change Mikel Rojo
Re: vxWorks network problems Steven M. Hartman
RE: When a record is changed twice very fast, camonitor only detects first change Mikel Rojo
<2011>
2025
2026
Re: When a record is changed twice very fast, camonitor only detects first change Tim Mooney
Windows XP Cygwin difficulties for building EPICS base Cid, Florencio A
<2011>
2025
2026
