Hi Florencio,
On 2011-05-24 Cid, Florencio A wrote:
> Thanks for the info/assistance. OK... I understand. How do I disable the
> optional building of the perl CA interface?
Follow Benjamin's suggestion of commenting out the "DIRS += cap5" line in the
src/Makefile
> Another question, for some
> reason the perl interpretor in my cygwin install is not working correctly.
> Should I try to uninstall and re-install cygwin perl module?
Perl is essential for building EPICS software, but it doesn't need the other
executables such as podchecker or pod2html that are used in src/cap5. If you
don't have any other issues with the build then your Perl installation is
probably working sufficiently, although eventually you might want to try re-
installing it.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- RE: Windows XP Cygwin difficulties for building EPICS base Cid, Florencio A
- Windows XP Cygwin difficulties for building EPICS base Cid, Florencio A
- Re: Windows XP Cygwin difficulties for building EPICS base Andrew Johnson
Re: Windows XP Cygwin difficulties for building EPICS base Benjamin Franksen
<2011>
2025
2026
<2011>
2025
2026
