1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Another gateway question
To: "'Kevin Tsubota'" <[email protected]>, <[email protected]>
Date: Tue, 24 May 2011 17:16:22 -0600
Hi Kevin,
First I should mention that a number of issues were fixed in the portable server “cas” library for R3.14.11, and that the portable ca server library is an significant component of the gateway. Some improvements were also made to the gateway code itself at that time. In particular, the put callback implementation, for gateways that permit writes, was substantially improved.
http://www.aps.anl.gov/epics/base/R3-14/11-docs/RELEASE_NOTES.html
I see that there are two “Network Connection Lost” messages in the write-access-granted output that you sent, and that dbcar also sees that all of the channels have disconnected twice. Two disconnects is maybe a strange result unless this number is reflecting the number of times that you restarted the gateway. If you leave this running for awhile do you see that the number of disconnects, as seen by dbcar is continuously increasing? Alternatively, does this number increase each time that the gateway is restarted? If this number of disconnects is always two soon after the IOC reboots, and isn’t increasing, then I fear something is amiss with the R3.13 db ca link code or the ca client library. It might help to type “i” in vxWorks, and then send the output from “tt <task id>” for the db ca link thread, and the ca client related threads that are running at close to the same priority.
Ø  Is it a vxworks / r3.13.x issue?
Its probably more likely to be an R3.13 issue than a vxWorks issue although I wasn’t aware that there were any issues with R3.13 clients accessing the R3.14 portable CA server library.
Does your R3.13 camonitor/caget connect ok to the R3.14 excas (which uses the same ca server library as the ca gateway)? A recent R3.14 CA reference manual will identify what PVs are available in excas. You might also try placing a test record in your R3.13 IOC which db ca links to an R3.14 excas.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
From: [email protected] [mailto:[email protected]] On Behalf Of Kevin Tsubota
Sent: Tuesday, May 24, 2011 11:47 AM
To: [email protected]
Subject: Another gateway question
I have another gateway issue, this time its legit J
My EPICS clients (caget, caput, camonitor and guis) can access my PVs behind my gateway (R3.14.9).  However, I have a MVME2304 running VxWorks 5.3.1 and EPICS R3.13.10 and it’s having issues with the gateway, basically its not connecting.  Before I added the gateway, it was directly accessing the channels in question via EPICS_CA_ADDR_LIST and it didn’t have any issues.
When the vxworks user doesn’t have write access in the gateway I get the following output for the channels behind the gateway:
( I cleaned up the output by removing the good channels and you can ignore the not connected ones).
no write access ‘dbcar‘ summary:
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:lsshutCmd.OUT k1:ao:ls:shutterCmd
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bto:btoTrack.OUT k1:ao:ls:ss:btoperm nNoWrite 605
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:lightOnPsd.INPB k1:ao:ls:ss:PsdSum nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:lsPropSt.INPA k1:ao:ls:ss:LaserOn nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:lsPropSt.INPB k1:ao:ls:ss:LShutOpen nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bto:pntState.INPA k1:ao:ls:ss:OnSky nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:tm5psd:lsPropSt.INPA k1:ao:ls:ss:LaserOn nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:tm5psd:lsPropSt.INPB k1:ao:ls:ss:LShutOpen nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:threshSel.NVL k1:ao:ls:ss:FdMirState nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:tm5psd:threshSel.NVL k1:ao:ls:ss:FdMirState nNoWrite 0
ncalinks 137 not connected 7 no_read_access 10 no_write_access 10
 nDisconnect 0 nNoWrite 605
 When giving read/write access to the vxworks user, I get the following errors and a different ‘dbcar’ output:
read/write access dbcar summary:
dbCa:exceptionCallback stat "Network connection lost" channel "unknown" context "k1laserserver:5064"
 nativeType DBR_invalid requestType DBR_invalid nativeCount 0 requestCount 0 noReadAccess noWriteAccess
May 23, 2011 17:13:34.846100273
    connected k1laserserver:5064 k1:ao:ls:bpsd:lsshutCmd.OUT k1:ao:ls:shutterCmd nDisconnect 2
    connected k1laserserver:5064 k1:ao:ls:bto:btoTrack.OUT k1:ao:ls:ss:btoperm nDisconnect 2 nNoWrite 2668
    connected k1laserserver:5064 k1:ao:ls:bpsd:lightOnPsd.INPB k1:ao:ls:ss:PsdSum nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:bpsd:lsPropSt.INPA k1:ao:ls:ss:LaserOn nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:bpsd:lsPropSt.INPB k1:ao:ls:ss:LShutOpen nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:bto:pntState.INPA k1:ao:ls:ss:OnSky nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:tm5psd:lsPropSt.INPA k1:ao:ls:ss:LaserOn nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:tm5psd:lsPropSt.INPB k1:ao:ls:ss:LShutOpen nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:bpsd:threshSel.NVL k1:ao:ls:ss:FdMirState nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:tm5psd:threshSel.NVL k1:ao:ls:ss:FdMirState nDisconnect 2 nNoWrite 0
ncalinks 137 not connected 7 no_read_access 0 no_write_access 0
 nDisconnect 20 nNoWrite 2668
This crate is on a separate network but I have the EPICS_CA_ADDR_LIST set to find the gateway which is using the default EPICS_CA_SERVER_PORT.
I’ve also logged into my unix server as the vxworks user and it doesn’t have any problems accessing the gateway channels.
Only from vxworks.  Is it a vxworks / r3.13.x issue?
Any thoughts on this would be appreciated.
Mahalo!
Kevin Tsubota
WM Keck Observatory
RE: Another gateway question Kevin Tsubota
Prev: Re: Suggestion for IOC log server Andrew Johnson
Next: How to use multiple line text input in CSS? [SEC=UNCLASSIFIED] WANG, Jian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Another gateway question Kevin Tsubota
Next: RE: Another gateway question Kevin Tsubota
