1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Another gateway question
To: <[email protected]>
Date: Tue, 24 May 2011 07:46:44 -1000
I have another gateway issue, this time its legit J
My EPICS clients (caget, caput, camonitor and guis) can access my PVs behind my gateway (R3.14.9).  However, I have a MVME2304 running VxWorks 5.3.1 and EPICS R3.13.10 and it’s having issues with the gateway, basically its not connecting.  Before I added the gateway, it was directly accessing the channels in question via EPICS_CA_ADDR_LIST and it didn’t have any issues.
When the vxworks user doesn’t have write access in the gateway I get the following output for the channels behind the gateway:
( I cleaned up the output by removing the good channels and you can ignore the not connected ones).
no write access ‘dbcar‘ summary:
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:lsshutCmd.OUT k1:ao:ls:shutterCmd
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bto:btoTrack.OUT k1:ao:ls:ss:btoperm nNoWrite 605
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:lightOnPsd.INPB k1:ao:ls:ss:PsdSum nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:lsPropSt.INPA k1:ao:ls:ss:LaserOn nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:lsPropSt.INPB k1:ao:ls:ss:LShutOpen nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bto:pntState.INPA k1:ao:ls:ss:OnSky nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:tm5psd:lsPropSt.INPA k1:ao:ls:ss:LaserOn nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:tm5psd:lsPropSt.INPB k1:ao:ls:ss:LShutOpen nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:bpsd:threshSel.NVL k1:ao:ls:ss:FdMirState nNoWrite 0
    connected k1laserserver:5064 no_read_access no_write_access k1:ao:ls:tm5psd:threshSel.NVL k1:ao:ls:ss:FdMirState nNoWrite 0
ncalinks 137 not connected 7 no_read_access 10 no_write_access 10
 nDisconnect 0 nNoWrite 605
 When giving read/write access to the vxworks user, I get the following errors and a different ‘dbcar’ output:
read/write access dbcar summary:
dbCa:exceptionCallback stat "Network connection lost" channel "unknown" context "k1laserserver:5064"
 nativeType DBR_invalid requestType DBR_invalid nativeCount 0 requestCount 0 noReadAccess noWriteAccess
May 23, 2011 17:13:34.846100273
    connected k1laserserver:5064 k1:ao:ls:bpsd:lsshutCmd.OUT k1:ao:ls:shutterCmd nDisconnect 2
    connected k1laserserver:5064 k1:ao:ls:bto:btoTrack.OUT k1:ao:ls:ss:btoperm nDisconnect 2 nNoWrite 2668
    connected k1laserserver:5064 k1:ao:ls:bpsd:lightOnPsd.INPB k1:ao:ls:ss:PsdSum nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:bpsd:lsPropSt.INPA k1:ao:ls:ss:LaserOn nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:bpsd:lsPropSt.INPB k1:ao:ls:ss:LShutOpen nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:bto:pntState.INPA k1:ao:ls:ss:OnSky nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:tm5psd:lsPropSt.INPA k1:ao:ls:ss:LaserOn nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:tm5psd:lsPropSt.INPB k1:ao:ls:ss:LShutOpen nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:bpsd:threshSel.NVL k1:ao:ls:ss:FdMirState nDisconnect 2 nNoWrite 0
    connected k1laserserver:5064 k1:ao:ls:tm5psd:threshSel.NVL k1:ao:ls:ss:FdMirState nDisconnect 2 nNoWrite 0
ncalinks 137 not connected 7 no_read_access 0 no_write_access 0
 nDisconnect 20 nNoWrite 2668
This crate is on a separate network but I have the EPICS_CA_ADDR_LIST set to find the gateway which is using the default EPICS_CA_SERVER_PORT.
I’ve also logged into my unix server as the vxworks user and it doesn’t have any problems accessing the gateway channels.
Only from vxworks.  Is it a vxworks / r3.13.x issue?
Any thoughts on this would be appreciated.
Mahalo!
Kevin Tsubota
WM Keck Observatory
RE: Another gateway question Jeff Hill
Prev: Re: vxWorks network problems Andrew Johnson
Next: RE: Suggestion for IOC log server Davidsaver, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Device Support for Nemic Lambda Power Supplies Jack
Next: RE: Another gateway question Jeff Hill
