1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Suggestion for IOC log server
To: "EPICS Tech Talk" <[email protected]>
Date: Tue, 24 May 2011 13:58:10 -0400
Another nice feature of conserver is that the local daemon can redirect clients to daemons running on other machines.  So you can attach to procServ instances running on other hosts directly without needing (or allowing) ssh access.
For our test lab we have some RTEMS iocs and soft iocs on several hosts.  The method for connection and logging is uniform.
$ console -u
 mad                        up   jshah@localhost
 timing                     up   mdavidsaver@localhost
 sumtest                    up   <none>
 wiener                     up   <none>
 OM_Lab                     up   <none>
 RadMonAvg                  up   <none>
 RadMon                     up   <none>
 vioc                       down <none>
 fritz                      up   <none>
 v7768                      up   <none>
 alpha                      up   <none>
 rftiming                   up   <none>
 acqiris                    up   <none>
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Ralph Lange
> Sent: Tuesday, May 24, 2011 10:54 AM
> To: EPICS Tech Talk
> Subject: Re: Suggestion for IOC log server
> On 24.05.2011 16:33 Williams Jr., Ernest L. wrote:
> > Hi
> > Is this the same as procServ
> One layer above.
> procServ allows telnet access to soft IOCs - it is the "soft" one
> channel version of a console server (aka Moxa box or equivalent).
> Conserver [1] is a daemon that connects to console connections -
> provided by procServ, Moxa boxes, serial lines, etc.
> The conserver daemon basically keeps the connection to all the consoles
> up and does the logging. It also provides a TCP based service that
> allows
> users to connect to consoles by means of a client program called
> console. The conserver daemon provides authentication for these user
> connections,
> makes sure only one gets write access, etc.
> The user calls "console <iocname>", which connects to the conserver
> daemon.
> The conserver daemon authenticates the user, and connects the user to
> the console connection of the specified IOC.
> That IOC can be a soft IOC under procServ, a VME IOC connected to a
> terminal server, anything serial connected somehow to something. The
> connection
> details are part of the conserver daemon configuration, the user only
> needs the IOC name.
> Ralph
> [1] http://www.conserver.com/
Re: Suggestion for IOC log server J. Lewis Muir
Device Support for Nemic Lambda Power Supplies Anthony Andrews
Re: Device Support for Nemic Lambda Power Supplies Eric Norum
Suggestion for IOC log server Abadie Lana
Re: Suggestion for IOC log server Ralph Lange
Re: Suggestion for IOC log server Williams Jr., Ernest L.
Prev: Another gateway question Kevin Tsubota
Next: Re: Suggestion for IOC log server J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Suggestion for IOC log server Ralph Lange
