1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Suggestion for IOC log server
To: EPICS Tech Talk <[email protected]>
Date: Tue, 24 May 2011 14:33:43 +0200
Hi all,
Our environment : Linux RH5.6, 64-bits
I would like to make a change in the iocLogServer.c and in particular to always force the close and open of the log file when the IOC log server catches a SIGHUP.
Currently it checks the file name is not the same one to perform the action :
L 908  if (strcmp(ioc_log_file_name, pserver->outfile) == 0)
Why is this a problem?
We are using logrotate in our system. We tried several scenarios but no way to make it work properly without using a full script. I described the different case we tried.
1)      Simple log rotate configuration (log file being moved, compressed and new one with the same name is created). The iocLogServer still points to the log file being moved and SIGHUP does not affect (because of the check no change on this variable). As a consequence the new file with the same name is always empty.
2)      Then I tried copytruncate, copy with a command to empty file : here the problem was the size always grewing until the file limit, the iocLogServer was always dumping its buffer (which was non human readable characters).
We also explore this EPICS_IOC_LOG_FILE_COMMAND but without success, still the same issue as we want to keep the same path.
Also we didn’t want to restart the iocLogServer each time we logrotate...
So the simplest solution I came up with was to remove this check. If this check is really needed, a flag can be added at start up of the IOC log server to see if one wants to force the update
So thanks for your comments/feedback and I would appreciate if IOCLog gurus can give their feedback on that issue...I may have miss something here on the reason of the check and request
Br
Lana
Re: Suggestion for IOC log server Ralph Lange
Re: Suggestion for IOC log server Andrew Johnson
Device Support for Nemic Lambda Power Supplies Anthony Andrews
Re: Device Support for Nemic Lambda Power Supplies Eric Norum
Prev: Re: Windows XP Cygwin difficulties for building EPICS base Dirk Zimoch
Next: Re: vxWorks network problems Steven M. Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Device Support for Nemic Lambda Power Supplies Eric Norum
Next: Re: Suggestion for IOC log server Ralph Lange
