1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Device Support for Nemic Lambda Power Supplies
To: EPICS Tech Talk <[email protected]>
Date: Mon, 23 May 2011 21:16:23 -0700
I suggest using StreamDevice for message-based devices (serial, GPIB, network).
Recent versions of ASYN have a template for setting up such a device:
/usr/local/epics/R3.14.12/modules/soft/synApps_5_5/support/asynR4-16/bin/darwin-x86/makeSupport.pl -t streamSCPI example
For an example of instrument support based on this template, have a look at Keithley6487-1.0.tar.gz
The example application shows how to connect to the device through a terminal server using the RFC2217 protocol
On May 23, 2011, at 8:57 PM, Anthony Andrews wrote:
Hello everyone,
My name is Tony and I’m a student at Idaho State University.  I’ve been doing a senior project to help establish an EPICS control system for the Idaho Accelerator Center.  I have been trying to create a control system specifically for a Nemic-Lambda ZUP (20 V 10A) magnet power supply.
So far, I have hooked the power supply into one of the ports of a MOXA 6650-8 terminal server using a RS485 (4wire) cable.  Then I sent commands to the port with telnet 134.50.3.107 4002 to change the current, display the model name, and so forth.  One example of a command that I use is:
:ADR01;:MDL?;
which serves as both an initialization command and displays the make and model of the power supply which has address 01.  Now, the next step is to figure out a way to turn those commands into process variables that I can monitor or change with MEDM.
So, I found a paper called “How to create EPICS device support for a simple serial or GPIB device” written by W. Eric Norum.  Since the power supply is a kind of serial device I figured that it would be pretty close to what I need to do.  However, I’m a little confused as to what to do in my situation on one part.
In the paper there’s a section called “Create a new device support module”, which shows how to create an EPICS application using the makeSupport.pl script.  In the paper, after he creates a directory, he runs the command:
/home/EPICS/modules/soft/asyn/bin/linux-x86/makeSupport.pl –t devGpib AB300
So, my question is: since I’m not using a GPIB device can I still use this kind of command?  Would I have to change the devGpib part of the above command to something else?  I was thinking that since there is a file named devGpib.dbd that maybe that has something to do with the command above.
Hypothetically, if I were to replace the devGpib in the above command with another .dbd file called drvAsynIPPort would that create an EPICS application for telnet type devices?  Then can I still just follow this paper for the rest of it?  Or, if you think that this wouldn’t work, could you give me any other papers, sources, or example files to look through which would help me to create device support?  Thank you.
Eric Norum
[email protected]
Suggestion for IOC log server Abadie Lana
Device Support for Nemic Lambda Power Supplies Anthony Andrews
Prev: Device Support for Nemic Lambda Power Supplies Anthony Andrews
Next: Re: Device Support for Nemic Lambda Power Supplies Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Suggestion for IOC log server Abadie Lana
