1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Suggestion for IOC log server
To: EPICS Tech Talk <[email protected]>
Date: Tue, 24 May 2011 16:53:59 +0200
On 24.05.2011 16:33 Williams Jr., Ernest L. wrote:
Hi
Is this the same as procServ
One layer above.
procServ allows telnet access to soft IOCs - it is the "soft" one channel version of a console server (aka Moxa box or equivalent).
Conserver [1] is a daemon that connects to console connections - provided by procServ, Moxa boxes, serial lines, etc.
The conserver daemon basically keeps the connection to all the consoles up and does the logging. It also provides a TCP based service that allows users to connect to consoles by means of a client program called console. The conserver daemon provides authentication for these user connections, makes sure only one gets write access, etc.
The user calls "console <iocname>", which connects to the conserver daemon.
The conserver daemon authenticates the user, and connects the user to the console connection of the specified IOC.
That IOC can be a soft IOC under procServ, a VME IOC connected to a terminal server, anything serial connected somehow to something. The connection details are part of the conserver daemon configuration, the user only needs the IOC name.
Ralph
[1] http://www.conserver.com/
RE: Suggestion for IOC log server Davidsaver, Michael
Device Support for Nemic Lambda Power Supplies Anthony Andrews
Re: Device Support for Nemic Lambda Power Supplies Eric Norum
Suggestion for IOC log server Abadie Lana
Re: Suggestion for IOC log server Ralph Lange
Re: Suggestion for IOC log server Williams Jr., Ernest L.
Prev: Re: Suggestion for IOC log server Williams Jr., Ernest L.
Next: Re: Windows XP Cygwin difficulties for building EPICS base Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Suggestion for IOC log server Davidsaver, Michael
