1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vxWorks network problems
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Tue, 24 May 2011 10:32:10 -0500
Hi Dirk,
On 2011-05-24 Dirk Zimoch wrote:
> Has anyone changed TCP_SND_SIZE_DFLT or TCP_RCV_SIZE_DFLT in vxWorks?
Not here.
> My settings are at the moment:
> #define NUM_64          800             /* default 100 */
> #define NUM_128         800             /* default 100 */
> #define NUM_256         100             /* default 40  */
> #define NUM_512         100             /* default 40  */
> #define NUM_1024        100             /* default 25  */
> #define NUM_2048        100             /* default 25  */
> #define NUM_SYS_64      1024            /* default 64  */
> #define NUM_SYS_128     1024            /* default 64  */
> #define NUM_SYS_256     512             /* default 64  */
> #define NUM_SYS_512     512             /* default 64  */
We have two different settings for these depending on the IOC's client load:
125, 400, 50, 25, 25, 25  and  256*4  for the smaller IOCs, and
250, 400, 50, 50, 25, 25  and  1024*2, 512*2 for the larger ones.
Note that in recent vxWorks 6.x releases they've replaced the network stack
*again*, and the new one goes back to the original configuration of just
setting the maximum amount of RAM the stack is allowed to use.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
vxWorks network problems Dirk Zimoch
Re: vxWorks network problems Steven M. Hartman
Re: vxWorks network problems Dirk Zimoch
Prev: Re: Windows XP Cygwin difficulties for building EPICS base Andrew Johnson
Next: Another gateway question Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vxWorks network problems Steven M. Hartman
Next: Re: vxWorks network problems Steven M. Hartman
