1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Xenomai Linux
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Tue, 31 May 2011 16:28:50 +0000
Dirk,
While not the same thing, we have looked briefly at porting EPICS to the Linux RT_PREEMPT kernel. EPICS will, of course, work with the RT_PREEMPT kernel, but this is not the same as saying it works as you would expect if you set the EPICS threads to real-time priorities. In fact, we know its behaviour is not ideal for a realtime system and, as a result, there is a Launchpad blueprint to add Posix realtime support for osdMessageQueue, which is the biggest problem we spotted (there may be more). Other than this, we found the RT_PREEMPT kernel worked well, with minimal pain to us.
So I think, with a general movement away from specialist real-time systems, I think we need to look at the EPICS behaviour with real-time Linux kernels, and possibly try and recommend one more than others. I am not sure how many of these problems are common to all Linux real-time kernel implementations and how many are specific to one implementation. Anyway, looking at this issue sounds a good codeathon task.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On
> Behalf Of Andrew Johnson
> Sent: 31 May 2011 16:24
> To: Dirk Zimoch
> Subject: Re: Xenomai Linux
> Hi Dirk,
> On 2011-05-30 Dirk Zimoch wrote:
> > Has anyone considered porting EPICS to Xenomai real-time Linux?
> > Maybe even started working on this issue?
> I had not heard of Xenomai before, and I'm not aware of anyone doing such a
> port so if you get no other responses the floor is all yours.
> Xenomai looks interesting, do you have specific hardware that is already
> running it?  Which skin are you looking at?  I would guess the native one, but
> I've not looked at the others very closely.
> - Andrew
> Optimization is the process of taking something that works and
> replacing it with something that almost works, but costs less.
> -- Roger Needham
Xenomai Linux Dirk Zimoch
Re: Xenomai Linux Andrew Johnson
Prev: Re: CA beacon routing error S_errno_ECONNREFUSED J. Lewis Muir
Next: RE: asyn driver on Windows XP Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Xenomai Linux Andrew Johnson
Next: Re: Xenomai Linux Dirk Zimoch
