1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA beacon routing error S_errno_ECONNREFUSED
To: Jeff Hill <[email protected]>
Cc: "'EPICS Tech Talk'" <[email protected]>
Date: Tue, 31 May 2011 11:20:38 -0500
On 5/20/11 11:08 AM, Jeff Hill wrote:
> In any case, the indirect cause might be an explicit unicast address in
> EPICS_CAS_BEACON_ADDR_LIST (defaulting to EPICS_CA_ADDR_LIST). The RFC's say
> that the network kernel can respond with "destination unreachable" ICMP
> error response to a IP packet with a unicast destination address, but not to
> a IP packet with a broadcast destination address. Since the ICMP destination
> unreachable isn't returned if there is a valid udp receiver for the
> destination frame then starting and stopping the other ca server might have
> an impact on the occurrence of the message.
Hi, Jeff.
Thanks for your help.  Based on your suggestion that the
EPICS_CAS_BEACON_ADDR_LIST, I added the following environment
settings to both IOCs and rebooted:
putenv "EPICS_CAS_AUTO_BEACON_ADDR_LIST=NO"
putenv "EPICS_CAS_BEACON_ADDR_LIST=192.168.0.127 192.168.0.255"
The CA beacon routing error messages on the consoles have now
gone away.
Thanks!
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT
CA beacon routing error S_errno_ECONNREFUSED J. Lewis Muir
RE: CA beacon routing error S_errno_ECONNREFUSED Jeff Hill
Prev: Re: Xenomai Linux David Kline
Next: RE: Xenomai Linux nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CA beacon routing error S_errno_ECONNREFUSED Jeff Hill
Next: trouble with 64-bit Window7 Matt Newville
