1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Forward Link v.s. Scan them all ?
To: <[email protected]>
Cc: [email protected]
Date: Sun, 5 Jun 2011 19:41:28 -0700
On Jun 5, 2011, at 7:34 PM, <[email protected]> wrote:
> Hi, all;
> I have a long series of bi record to process, which have an access to
> a hardware register, say, every 5 seconds.
> The number of records reaches a few to several thousands. In this case,
> which one of the following two options is better or no essential
> difference from performance point of view?
> 1)Chains all the records by using FLNK and process the first one every
> 5 second
A FLNK chain of several thousand records is likely to cause stack overflow on RTEMS or vxWorks and perhaps even on Linux/OS X.
> 2)Put them all into the “5 second” scan list
> I recognize that measuring it is no big deal, but I´d like to ask the
> experts first expecting one of you to point out something else to
> consider, which I may be overlooking, other than performance issue.
> Thanks a lot in advance.
> J. Odagiri, High Energy Research Organization (KEK)
Eric Norum
[email protected]
Re: Forward Link v.s. Scan them all ? jun-ichi.odagiri
Xenomai Linux Dirk Zimoch
Re: Xenomai Linux Andrew Johnson
Re: Xenomai Linux Dirk Zimoch
Prev: Forward Link v.s. Scan them all ? jun-ichi.odagiri
Next: Re: Forward Link v.s. Scan them all ? jun-ichi.odagiri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
