W dniu 2011-06-06 15:33, Kasemir, Kay pisze:
On 6/6/11 08:59 , "Paweł Prędki"<[email protected]> wrote:
Is it possible to do such a thing in BOY? There is an Image widget but I
believe it's for static images only.
The "Intensity Graph" widget displays waveforms that are really grayscale
images.
For example:
waveform with 10000 elements, "width" 100 means:
Elements 0...99 are the first row of the image,
elements 100..199 are the second row of the image and so on.
You need to specify the minimum and maximum element value,
like 0 and 255, which will then be mapped to black...white
or some other color map of your choosing.
-Kay
Hello Kay,
Thanks for your reply. That would be a good way to do it for one-channel
(grayscale) images. I believe the cameras we will be dealing with will
provide RGB (color) images.
I understand there is no straightforward way to do it. There is no image
record type in EPICS that clients could understand. Do you think there
is a need for such a thing? Like you said, a simple waveform could store
such raw image data in a BMP format without a header and the clients
would then be able to draw it.
Paweł Prędki
Technical University of Lodz
Department of Microelectronics and Computer Science
ul. Wolczanska 221/223, 90-924 Lodz, Poland
tel. +4842 6312720
- Re: Dynamic images in BOY Ned Arnold
- Re: Dynamic images in BOY Kasemir, Kay
<2011>
2025
2026
<2011>
2025
2026
