1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dynamic images in BOY
To: Paweł Prędki <[email protected]>
Cc: TechTalk <[email protected]>
Date: Mon, 6 Jun 2011 09:40:31 -0500
Hi -
You should probably look at Mark Rivers' areaDetector ... he has solved most of the problems with image type data in a very modular fashion.  If your needs are somewhat different just add a plug-able module.
http://cars9.uchicago.edu/software/epics/
  Ned
On Jun 6, 2011, at 9:28 AM, Paweł Prędki wrote:
> W dniu 2011-06-06 15:33, Kasemir, Kay pisze:
>> On 6/6/11 08:59 , "Paweł Prędki"<[email protected]>  wrote:
>>> Is it possible to do such a thing in BOY? There is an Image widget but I
>>> believe it's for static images only.
>> The "Intensity Graph" widget displays waveforms that are really grayscale
>> images.
>> For example:
>> waveform with 10000 elements, "width" 100 means:
>> Elements 0...99 are the first row of the image,
>> elements 100..199 are the second row of the image and so on.
>> You need to specify the minimum and maximum element value,
>> like 0 and 255, which will then be mapped to black...white
>> or some other color map of your choosing.
>> -Kay
> Hello Kay,
> Thanks for your reply. That would be a good way to do it for one-channel (grayscale) images. I believe the cameras we will be dealing with will provide RGB (color) images.
> I understand there is no straightforward way to do it. There is no image record type in EPICS that clients could understand. Do you think there is a need for such a thing? Like you said, a simple waveform could store such raw image data in a BMP format without a header and the clients would then be able to draw it.
> Regards,
> Paweł Prędki
> Technical University of Lodz
> Department of Microelectronics and Computer Science
> ul. Wolczanska 221/223, 90-924 Lodz, Poland
> tel. +4842 6312720
Re: Dynamic images in BOY Kasemir, Kay
Re: Dynamic images in BOY Paweł Prędki
Prev: Re: Dynamic images in BOY Paweł Prędki
Next: Re: Compiling Problem windows J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Dynamic images in BOY Paweł Prędki
