On 6/6/11 2:53 AM, Brands Helge wrote:
> Hi,
> I have some troubles with make on windows-x64 since the revision 12242 I
> got :
> /bin/sh: REM: command not found
> make[3]: *** [../../../bin/windows-x64/convertRelease.pl] Error 127
> make[2]: *** [install.windows-x64] Error 2
> make[1]: *** [tools.install] Error 2
> make: *** [src.install] Error 2
> The cygwin-x86 and the win32-x86 on the same machine runs without any
> problem
Hi, Brands.
According to
<https://code.launchpad.net/~epics-core/epics-base/3.14>,
Andrew Johnson made a change in revision 12242 which may have
caused this new behavior. This change is likely based on Ben
Franksen's email to Tech-Talk:
<http://www.aps.anl.gov/epics/tech-talk/2011/msg01002.php>.
However, since I see the following in your output,
I'm confused as to why you're running "/bin/sh" if you are
performing a native windows-x64 build. I don't have experience
building for Windows, but that doesn't seem right. I would
expect you to be using cmd.exe for your build. Can you try
switching to cmd.exe? I think the build system is expecting to
use REM as a comment, which would work in cmd.exe, but is not a
comment in /bin/sh.
Lewis
- RE: Compiling Problem windows Brands Helge
- Compiling Problem windows Brands Helge
Re: Dynamic images in BOY Ned Arnold
Re: Compiling Problem windows Andrew Johnson
<2011>
2025
2026
<2011>
2025
2026
