1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: AreaDetector: Prosilica camera on different subnet?
To: "Robert Petkus" <[email protected]>, "Bob Gunion" <[email protected]>
Cc: [email protected]
Date: Wed, 15 Jun 2011 14:32:30 -0500
Actually the Prosilica areaDetector driver cannot currently do this. The reason is that the camera is found by its Unique ID rather than its  IP address. This is convenient because cameras can use DHCP and do not need a fixed IP address.  But it won't work across subnets because it requires a broadcast to find the cameras by Unique ID. We could modify the driver to add logic to allow IP address or IP name in place of Unique ID.
Sent: Wed 6/15/2011 12:10 PM
To: Bob Gunion
Subject: Re: AreaDetector: Prosilica camera on different subnet?
If the both the IOC and camera allow a default gateway to be configured,
you can keep them on separate subnets and simply use a router.  The
router can be either a server or a multi-layer switch with an interface
on each of the subnets.  The router interface addresses will be the
gateway addresses configured on the IOC and camera.  From there one
could create policies to allow only traffic from the (2) devices to span
subnets if there are security concerns.
Robert Petkus
Bldg. 902-B, 17 Cornell Avenue
National Synchrotron Light Source II
Brookhaven National Laboratory
Upton, New York 11973
Tel.    : +1 (631) 344 3258
Fax.    : +1 (631) 344 8085
http://www.bnl.gov/nsls2
On 6/15/11 12:59 PM, Bob Gunion wrote:
> I have a Prosilica GigE camera (model GC1380H) which is on a different subnet from the desired location of my ioc.  Does the prosilica driver for areaDetector support this?  If not, would this be a worthwhile contribution, or is it advisable to keep both on the same subnet?
> Thanks,
> Bob Gunion
Re: AreaDetector: Prosilica camera on different subnet? Bob Gunion
Re: AreaDetector: Prosilica camera on different subnet? Robert Petkus
Prev: Retirement with epics version still < pi Chestnut, Ronald P.
Next: Re: AreaDetector: Prosilica camera on different subnet? Bob Gunion
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AreaDetector: Prosilica camera on different subnet? Robert Petkus
