1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AreaDetector: Prosilica camera on different subnet?
To: Mark Rivers <[email protected]>, Robert Petkus <[email protected]>
Cc: [email protected]
Date: Wed, 15 Jun 2011 15:06:45 -0700
I think it's not a difficult change: call PvCameraOpenByAddr if given an IP address, or PvCameraOpen if a unique ID - but with that I've exhausted my knowledge of the Prosilica API.  Perhaps I'll give it a try and see if there are problems (functionality/performance limitations?).
Bob
On Jun 15, 2011, at 12:32 PM, Mark Rivers wrote:
> Actually the Prosilica areaDetector driver cannot currently do this. The reason is that the camera is found by its Unique ID rather than its  IP address. This is convenient because cameras can use DHCP and do not need a fixed IP address.  But it won't work across subnets because it requires a broadcast to find the cameras by Unique ID. We could modify the driver to add logic to allow IP address or IP name in place of Unique ID.
> Mark
> ________________________________
> From: [email protected] on behalf of Robert Petkus
> Sent: Wed 6/15/2011 12:10 PM
> To: Bob Gunion
> If the both the IOC and camera allow a default gateway to be configured,
> you can keep them on separate subnets and simply use a router.  The
> router can be either a server or a multi-layer switch with an interface
> on each of the subnets.  The router interface addresses will be the
> gateway addresses configured on the IOC and camera.  From there one
> could create policies to allow only traffic from the (2) devices to span
> subnets if there are security concerns.
> Robert Petkus
> Bldg. 902-B, 17 Cornell Avenue
> National Synchrotron Light Source II
> Brookhaven National Laboratory
> Upton, New York 11973
> Tel.    : +1 (631) 344 3258
> Fax.    : +1 (631) 344 8085
> http://www.bnl.gov/nsls2
> On 6/15/11 12:59 PM, Bob Gunion wrote:
>> I have a Prosilica GigE camera (model GC1380H) which is on a different subnet from the desired location of my ioc.  Does the prosilica driver for areaDetector support this?  If not, would this be a worthwhile contribution, or is it advisable to keep both on the same subnet?
>> Thanks,
>> Bob Gunion
RE: AreaDetector: Prosilica camera on different subnet? Mark Rivers
AreaDetector: Prosilica camera on different subnet? Bob Gunion
Re: AreaDetector: Prosilica camera on different subnet? Robert Petkus
Prev: RE: AreaDetector: Prosilica camera on different subnet? Mark Rivers
Next: Re: Sequencer Preprocessor Build Rules Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: AreaDetector: Prosilica camera on different subnet? Mark Rivers
