Am Freitag, 10. Juni 2011, um 17:48:09 schrieben Sie:
> On 6/10/11 10:14 AM, Andrew Johnson wrote:
> > Hi Lewis,
> > On 2011-06-09 J. Lewis Muir wrote:
> >> My vote would be to fix the preprocessor; it shouldn't do that
> >> substitution.
> > That means removing $(OP_SYS_CPPFLAGS) from the options passed to the
> > preprocessor when we run it before the SNC. However anyone who has an
> > #ifdef vxWorks that modifies their SNL code when building it for
> > vxWorks isn't going to be very happy with that.
> Hi, Andrew.
> I still feel it doesn't mean removing $(OP_SYS_CPPFLAGS) from
> the options passed to the preprocessor but rather means fixing
> the preprocessor itself. I haven't looked at it, but I'm
> guessing the preprocessor is a C preprocessor.
It is certainly supposed to be one.
> If so, then the
> problem is that we're abusing the use of the C preprocessor by
> trying to use it on source that is not C; it's SNL. So, ideally
> we would have a preprocessor that could properly preprocess SNL.
I see no chance of something like this being implemented in the forseeable
future. It would also add another point of failure and create an extra burden
of maintenance (viz. how hard it is for me to get the new sequencer to compile
on Windows).
> My guess is that for this vxWorks.h problem, the C preprocessor
> sees a line starting with "%%" and concludes it is not a
> preprocessor command, hence the bad substitution; it would
> normally understand an include command and know not to
> substitute within the angle brackets. If this is the case, I
> think another workaround would be to use the SNL block escape
> syntax instead of the single line syntax:
> #include <vxWorks.h>
Yes, this should work (with the "#" as first character on the line).
> But I haven't tried this.
> Anyway, your "-DvxWorks=vxWorks" idea is a reasonable workaround
> (but it adds a little confusion due to being nonstandard since
> now the value must be vxWorks or else things will break). The
> real problem still remains. But maybe no one will run into it.
It's a kludge but not a bad one. It means you need to check for vxWorks using
#ifdef, but I think everyone does so anyway. The advantage is that the word
"vxWorks" can be freely used in your program, even as an identifier.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: Sequencer Preprocessor Build Rules Andrew Johnson
- Sequencer Preprocessor Build Rules Andrew Johnson
- Re: Sequencer Preprocessor Build Rules J. Lewis Muir
Re: AreaDetector: Prosilica camera on different subnet? Bob Gunion
Re: radiation damage to electronics inside accelerator tunnel? Benjamin Franksen
<2011>
2025
2026
<2011>
2025
2026
