On 6/10/11 10:14 AM, Andrew Johnson wrote:
> Hi Lewis,
> On 2011-06-09 J. Lewis Muir wrote:
>> My vote would be to fix the preprocessor; it shouldn't do that
>> substitution.
> That means removing $(OP_SYS_CPPFLAGS) from the options passed to the
> preprocessor when we run it before the SNC. However anyone who has an #ifdef
> vxWorks that modifies their SNL code when building it for vxWorks isn't going
> to be very happy with that.
Hi, Andrew.
I still feel it doesn't mean removing $(OP_SYS_CPPFLAGS) from
the options passed to the preprocessor but rather means fixing
the preprocessor itself. I haven't looked at it, but I'm
guessing the preprocessor is a C preprocessor. If so, then the
problem is that we're abusing the use of the C preprocessor by
trying to use it on source that is not C; it's SNL. So, ideally
we would have a preprocessor that could properly preprocess SNL.
My guess is that for this vxWorks.h problem, the C preprocessor
sees a line starting with "%%" and concludes it is not a
preprocessor command, hence the bad substitution; it would
normally understand an include command and know not to
substitute within the angle brackets. If this is the case, I
think another workaround would be to use the SNL block escape
syntax instead of the single line syntax:
#include <vxWorks.h>
But I haven't tried this.
Anyway, your "-DvxWorks=vxWorks" idea is a reasonable workaround
(but it adds a little confusion due to being nonstandard since
now the value must be vxWorks or else things will break). The
real problem still remains. But maybe no one will run into it.
Lewis
- Re: Sequencer Preprocessor Build Rules Benjamin Franksen
- Sequencer Preprocessor Build Rules Andrew Johnson
- Re: Sequencer Preprocessor Build Rules J. Lewis Muir
- Re: Sequencer Preprocessor Build Rules Andrew Johnson
SNS CSS org.csstudio.basic.epics.product John Dobbins
<2011>
2025
2026
<2011>
2025
2026
