1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: radiation damage to electronics inside accelerator tunnel?
To: "'[email protected]'" <[email protected]>
Date: Wed, 15 Jun 2011 23:58:05 -0600
We have had similar problems with Heidenhain encoders, in our case it tends to lose communication with the endat cards.  Our encoders have some lead shielding but not sufficient to stop 3GeV electrons.  The shieldings helps, redesigning the devices to have them away from the beam pipe helps more.  We have just started to work with magneto-resistive absolute encoder design that so far appears to be holding up well.
We avoid putting electronics in the tunnel, however we have from time to time and in a few limited cases permanently installed electronics.   We generally try to keep them off of beam path and on the inside of the ring. In most of our cases they have been for signal processing applications where we have made the trade off between minimising cable lengths vrs accepting the shorter lifetime on the equipment.
Elder
_______________________
Subject:Re: radiation damage to electronics inside accelerator tunnel?
To:<[email protected]>
Date:
Thu, 16 Jun 2011 01:54:19 +0200
Am Dienstag, 14. Juni 2011, um 21:42:09 schrieb Hu, Yong:
> Hello All,
> Did anyone have experience putting electronics, especially Moxa NPort
> 5110[1] and IFW Intelligent Filter Wheel[2], inside accelerator(Linac,
> Booster, Storage Ring) tunnel? Any shielding required?
Don't know about the devices you listed, but I remember we had Heidenhain
position measurement systems near the vacuum chamber and these things became
very non-linear after a few weeks (i.e. they still gave back positions but
completely wrong ones).
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: RE: AreaDetector: Prosilica camera on different subnet? Mark Rivers
Next: Snr Controls Engineer Contract Position Australian Synchrotron Lou Corvetti
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: radiation damage to electronics inside accelerator tunnel? Mohan Ramanathan
Next: Hardware needed to setup an IOC Andrew Cox
