1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: radiation damage to electronics inside accelerator tunnel?
To: "Rarback, Harvey M." <[email protected]>, EPICS <[email protected]>
Cc: "Ringwall, Andrew D." <[email protected]>, [email protected], "Dao, Tom T." <[email protected]>, [email protected]
Date: Tue, 21 Jun 2011 08:31:40 -0500
Folks:
I been watching the stories of these radiation damage.
Let me give you all my perspective of what we saw long long time ago at APS and we have managed to handle these problems.
At APS we operate at 7.0 GeV.  The ID's we used had SSI based absolute encoders.  These encoders have CCD in them.  Its a know fact that CMOS has problem with neutron damage.
We started installing shielding of encoders and even then the absolute linear encoders started dying ( I am talking of back in 1995-2000 time frame).  At that time we started looking at alternate encoder and we started using virtual absolute encoders.  These are based on transistor and diodes.  We have since shielded most of the encoders and have had good luck since.
We also were the once to use smart servo motors back in 2000 time frame and ran in severe problem with damage to electronics resulting in motor run offs.
Most of the problem were related to neutron damage.
mohan
On Jun 20, 2011, at 2:21 PM, Rarback, Harvey M. wrote:
> 	Folks,
> Let me add another data point to the vulnerability of SSI encoders inside the beam tunnel near beam height.  We've had *seven* unrecoverable TR Electronics LT Series failures as well as a few Hall effect limit switch failures at SPEAR.  Shielding with ~1 cm of Pb seems to have fixed (or slowed down?) the failure rate.
> Potentiometers and LVDTs inside the tunnel make a great deal of sense.
>                               --Harvey
> Harvey Rarback                   phone: (650)926-3963
> SLAC National Accelerator Lab    fax:   (650)926-4100
> 2575 Sand Hill Road              home phone: (650)560-9111
> Menlo Park, CA 94025             [email protected]
>                                 http://ssrl.slac.stanford.edu/~rarback
>    "Always tell the truth, that way you don't have to keep track."
>                             Pogo
>> -----Original Message-----
>> From: [email protected] [mailto:tech-talk-
>> [email protected]] On Behalf Of Hu, Yong
>> Sent: Monday, June 20, 2011 9:24 AM
>> To: [email protected]; Josh Stein; Richard Farnsworth;
>> [email protected]; [email protected]
>> Cc: [email protected]
>> Subject: RE: radiation damage to electronics inside accelerator tunnel?
>> Thanks a lot for all of you sharing experiences and giving suggestions
>> which are really helpful for me to convince our Diagnostics Group to
>> re-design cabling and shielding.
>> Regarding position measurement encoder, we're going to use Potentiometer
>> and LVDT with stepper motor for beam diagnostics (slits, scrapers,
>> etc.). We think these kinds of analog encoders might have better
>> resistance to EMI and radiation.
>> Yong
Mohan Ramanathan						Senior Beamline Engineer
[email protected]						Advanced Photon Source
(630)-252-3773 (off)/(630)-822-5625(Cell)	Argonne National Laboratory
(630)-252-7187 (FAX)					Argonne, IL 60439
radiation damage to electronics inside accelerator tunnel? Hu, Yong
RE: radiation damage to electronics inside accelerator tunnel? austen.rose
RE: radiation damage to electronics inside accelerator tunnel? Hu, Yong
RE: radiation damage to electronics inside accelerator tunnel? Rarback, Harvey M.
Prev: RE: Fuzzy controller in EPICS Mark Rivers
Next: Re: Areadetector: driver for VDS Vosskuhler gigE camera? Jeffrey Gebhardt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: radiation damage to electronics inside accelerator tunnel? Rarback, Harvey M.
Next: Re: radiation damage to electronics inside accelerator tunnel? Elder Matias
