1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: FW: EPICS driver for SIS3302
To: "EPICS tech-talk" <[email protected]>
Date: Thu, 16 Jun 2011 22:50:52 +0200
I also think having an standard API in devLib is indeed necessary to allow easy usage of external codes/drivers which depend on DMA. And yes we have our own wheel but I should confess that I did not look much around at the time when I started design and implementation. The not-fully-complete documentation of my code can be found here: http://controls.web.psi.ch/cgi-bin/twiki/view/Main/VxWorksDmaDriver#API_and_Usage <http://controls.web.psi.ch/cgi-bin/twiki/view/Main/VxWorksDmaDriver#API_and_Usage> . It basically supports Universe-2 and Tempe for vxWorks.
I can offer some help maybe not in every aspect of this issue but at least and especially I would like to participate in details of the design and behaviour of API and/or code as we have quite some running applications already depending on (our) DMA driver.
Babak
From: [email protected] on behalf of Andrew Johnson
Sent: Thu 6/16/2011 7:20 PM
To: EPICS tech-talk
Subject: Re: FW: EPICS driver for SIS3302
There is obviously a need for a VME DMA API in devLib.  APS has been using one
I designed here for many years, and there are tech-talk messages archiving my
implementations of this for vxWorks for all 3 of the VME interface chips we
use here (VMEChip2, Universe-2, Tempe).  Recently Mark Rivers started using it
for some of his code and now Diamond have looked at it.  I believe that Till
has a slightly different API for RTEMS with implementations for the Universe-2
and Tempe chips, and PSI also wrote their own but I don't know what chips or
OSs that runs on.
I've already suggested that Michael Davidsaver add a pluggable DMA API to
devLib so we can stop reinventing this particular wheel, but I know he's busy
with work on NSLS-II so he might appreciate some help.  If anyone discusses
this topic in the future, /please/ use tech-talk (or core-talk) so others can
also join in.
- Andrew
On 2011-06-16 Ernest Williams wrote:
> From: Williams Jr., Ernest L.
> Sent: Wednesday, June 15, 2011 10:39 PM
> To: Korhonen Timo; Keahey, Pelham; Hu, Yong
> Cc: Szalata, Zenon M.; Straumann, Till; Kim, Kukhee; [email protected];
>  Allison, Stephanie; [email protected]; Williams Jr., Ernest L. Subject:
> Hi,
> This sounds like a great codeathon topic.
> Till are you interested in this as well?
> Can we get this kind of thing in devLib2 --> libCom ?
> Michael, what do you think?
> Cheers,
> Ernest
> From: Korhonen Timo [[email protected]]
> Sent: Wednesday, June 15, 2011 9:47 PM
> To: Keahey, Pelham; Williams Jr., Ernest L.; Hu, Yong
> Hi all,
> sorry for the late reply.
> The complicated part of our driver is that we make heavy use of DMA, and
> we have some libraries that are on top of the vxWorks BSPs. So it
>  unfortunately will need some work to get it to run on RTEMS; libCom did
>  not have this support (as far as I remember). It should, though - but this
>  is another issue.
> In any case we would be happy to share the driver. To understand it
>  somebody needs to look at the vxWorks dependent part, to be able to
>  replicate the API functions in RTEMS.
> best regards,
> Timo
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: FW: EPICS driver for SIS3302 Andrew Johnson
Prev: Creating an IOCs and CA cleints for beginners Cid, Florencio A
Next: Re: Creating an IOCs and CA cleints for beginners Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: FW: EPICS driver for SIS3302 Till Straumann
Next: Creating a Simple EPICS Sequencer Program Bradley Pietrzak
