Hi Pete,
On 2011-06-17 [email protected] wrote:
> In epics 3.14.11 it is possible to caput a long string (> 40 characters)
> using the following:
> caput -S mypv$ "some string that is longer than 40 characters"
Not quite; $ is a legal character in a record name, so to make this a long
strings the $ *must* follow the . in the PV name, i.e. you have to use mypv.$
or mypv.VAL$. The $ field modifier only works for fields of type DBF_*LINK or
for DBF_STRING fields which have size(>40) in the record type's DBD file.
> Is there an equivalent for writing long strings from an edm (version
> 1-12-28) text control or similar widget?
Yes, when writing EDM John Sinclair copied MEDM's support for string I/O to a
PV whose native type is an array of chars (which is what the above field
modifier does). Just point the regular EDM text widgets at a suitable PV.
> (In my particular case I want to write a long PV name into a DOL field)
You should be able to use this approach, mypv.DOL$
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- RE: long strings in edm peter.leicester
- long strings in edm peter.leicester
Re: Announce: pyexpander - a macro processor also capable of replacing msi Goetz Pfeiffer
<2011>
2025
2026
<2011>
2025
2026
