1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: long strings in edm
To: <[email protected]>
Date: Tue, 21 Jun 2011 10:34:24 +0000
Thanks for the info.
Does anyone know which version of edm this was added too. It appears our 1-12-28 (Mar2010) edm version doesn't support it.
Pete
-----Original Message-----
Sent: 17 June 2011 18:13
To: [email protected]
Cc: Leicester, Pete (DLSLtd,RAL,DIA)
Subject: Re: long strings in edm
Hi Pete,
On 2011-06-17 [email protected] wrote:
> In epics 3.14.11 it is possible to caput a long string (> 40 characters)
>  using the following:
> caput -S mypv$ "some string that is longer than 40 characters"
Not quite; $ is a legal character in a record name, so to make this a long
strings the $ *must* follow the . in the PV name, i.e. you have to use mypv.$
or mypv.VAL$.  The $ field modifier only works for fields of type DBF_*LINK or
for DBF_STRING fields which have size(>40) in the record type's DBD file.
> Is there an equivalent for writing long strings from an edm (version
> 1-12-28) text control or similar widget?
Yes, when writing EDM John Sinclair copied MEDM's support for string I/O to a
PV whose native type is an array of chars (which is what the above field
modifier does).  Just point the regular EDM text widgets at a suitable PV.
> (In my particular case I want to write a long PV name into a DOL field)
You should be able to use this approach, mypv.DOL$
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: long strings in edm Andrew Johnson
long strings in edm peter.leicester
Prev: RE: Areadetector: driver for VDS Vosskuhler gigE camera? tom.cobb
Next: Fuzzy controller in EPICS Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: long strings in edm Andrew Johnson
Next: Re: long strings in edm Andrew Johnson
