1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS_DEPRECATED and gcc-2.96
To: [email protected]
Date: Mon, 20 Jun 2011 13:52:13 -0500
Hi Dirk,
On 2011-06-20 Dirk Zimoch wrote:
> Unfortunately it seems that the Tornado 2.2 compiler (gcc-2.96, Linux
> version) does not understand  __attribute__((deprecated)):
> warning: `deprecated' attribute directive ignored
> So it seems that #ifdef __GNUC__ is not enough and the GCC version needs
> to be tested. However I don't know from which version on GCC understands
> deprecated. Maybe starting with version 3 ?
I can find it in the documentation for gcc 3.1 but not in 3.0.4.  I don't
think anyone's really going to be using the 3.0.x versions of GCC any more and
even if they do the result is only a warning, so I'll apply this patch:
=== modified file 'src/libCom/misc/compilerDependencies.h'
--- src/libCom/misc/compilerDependencies.h      2008-09-26 17:24:32 +0000
+++ src/libCom/misc/compilerDependencies.h      2011-06-20 18:48:47 +0000
@@ -95,7 +95,7 @@
  * Deprecation marker
-#ifdef __GNUC__
+#if defined( __GNUC__ ) && (__GNUC__ > 2)
 # define EPICS_DEPRECATED __attribute__((deprecated))
 #else
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
EPICS_DEPRECATED and gcc-2.96 Dirk Zimoch
Prev: Re: AreaDetector: Prosilica camera on different subnet? Bob Gunion
Next: RE: radiation damage to electronics inside accelerator tunnel? Rarback, Harvey M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS_DEPRECATED and gcc-2.96 Dirk Zimoch
Next: Areadetector: driver for VDS Vosskuhler gigE camera? Paul Martin
