1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS_DEPRECATED and gcc-2.96
Date: Mon, 20 Jun 2011 17:29:05 +0200
Hi all,
In base 3.14.12, the macro EPICS_DEPRECATED is defined in compilerDependencies.h as follows:
 * Deprecation marker
#ifdef __GNUC__
# define EPICS_DEPRECATED __attribute__((deprecated))
#else
#endif
Unfortunately it seems that the Tornado 2.2 compiler (gcc-2.96, Linux version) does not understand __attribute__((deprecated)):
warning: `deprecated' attribute directive ignored
So it seems that #ifdef __GNUC__ is not enough and the GCC version needs to be tested. However I don't know from which version on GCC understands deprecated. Maybe starting with version 3 ?
Dirk
Re: EPICS_DEPRECATED and gcc-2.96 Andrew Johnson
Prev: RE: a puzzle about using stream device driver Davidsaver, Michael
Next: Re: a puzzle about using stream device driver Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: a puzzle about using stream device driver Dirk Zimoch
Next: Re: EPICS_DEPRECATED and gcc-2.96 Andrew Johnson
