Geyang,
You probably want to disable scanning completely when the motor is not
moving, not just reduce the rate.
From the position-set record FLNK to a seq or similar that sets moving
to 1. Your position-read record can use the 'field(SDIS, "$(P)moving")'
and 'field(DISV, "0")' directly to process only when moving is 1. The
same for all other records that should only poll when moving.
If the device can be asked for "done" use this information to set moving
back to 0 and all polling stops. This record should as well poll only
when moving. If the device cannot be asked for "done", use a calcout
record to calculate "done" yourself.
"I/O Intr" only works if the device is sending status updates
automatically while moving, without being polled.
Dirk
Davidsaver, Michael wrote:
A simple way to get different scan rates based on a binary status. I
haven't checked that this example works, but I think it gives the basic
idea.
Record(bi, "$(P)moving") {
Record(fanout, "$(P)slow") {
Field(SDIS, "$(P)moving")
Field(DISV, "1")
Field(SCAN, "1 second")
Field(FLNK, "$(P):opticalscale")
Record(fanout, "$(P)fast") {
Field(DISV, "0")
Field(SCAN, ".1 second")
Record(ai, "$(P):opticalscale") {
Behavior of SDIS and DISV is described here:
http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-14_dbCommon
-----Original Message-----
[email protected]] On Behalf Of Silver
Sent: Monday, June 20, 2011 10:42 AM
To: tech-talk
Subject: a puzzle about using stream device driver
hi,
I am using stream device driver to communicate a galil motion control
which model is dmc21x3. To get the value of optical scale, I use a ai
record like this:
record(ai,"$(PREFIX):opticalscale")
field (DESC, "opticalscale position")
field (DTYP, "stream")
field (INP, "@dmc2143.proto ai_opticalscale motor")
field (SCAN, ".5 second")
In that, I use the period scan. It works fine.
But in most of time, the value doesn't change. That means the IOC has
to communicate with device periodly. As the value only changes during
the motor moving, may I use I/O Intr mode?
I checked the online document of stream device, seems the I/O Intr
mode
is not suitable for this case. Is there any good ways to avoid
checking
the devcie periodly?
Thanks a lot for your help.
Best regards
Geyang 2011-06-20
- a puzzle about using stream device driver Silver
- RE: a puzzle about using stream device driver Davidsaver, Michael
EPICS_DEPRECATED and gcc-2.96 Dirk Zimoch
RE: radiation damage to electronics inside accelerator tunnel? Hu, Yong
<2011>
2025
2026
<2011>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
