A simple way to get different scan rates based on a binary status. I
haven't checked that this example works, but I think it gives the basic
idea.
Record(bi, "$(P)moving") {
Record(fanout, "$(P)slow") {
Field(SDIS, "$(P)moving")
Field(DISV, "1")
Field(SCAN, "1 second")
Field(FLNK, "$(P):opticalscale")
Record(fanout, "$(P)fast") {
Field(DISV, "0")
Field(SCAN, ".1 second")
Record(ai, "$(P):opticalscale") {
Behavior of SDIS and DISV is described here:
http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-14_dbCommon
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Silver
> Sent: Monday, June 20, 2011 10:42 AM
> To: tech-talk
> Subject: a puzzle about using stream device driver
> hi,
> I am using stream device driver to communicate a galil motion control
> which model is dmc21x3. To get the value of optical scale, I use a ai
> record like this:
> record(ai,"$(PREFIX):opticalscale")
> field (DESC, "opticalscale position")
> field (DTYP, "stream")
> field (INP, "@dmc2143.proto ai_opticalscale motor")
> field (SCAN, ".5 second")
> In that, I use the period scan. It works fine.
> But in most of time, the value doesn't change. That means the IOC has
> to communicate with device periodly. As the value only changes during
> the motor moving, may I use I/O Intr mode?
> I checked the online document of stream device, seems the I/O Intr
mode
> is not suitable for this case. Is there any good ways to avoid
checking
> the devcie periodly?
> Thanks a lot for your help.
> Best regards
> Geyang 2011-06-20
- Re: a puzzle about using stream device driver Dirk Zimoch
- a puzzle about using stream device driver Silver
RE: radiation damage to electronics inside accelerator tunnel? austen.rose
EPICS_DEPRECATED and gcc-2.96 Dirk Zimoch
<2011>
2025
2026
RE: a puzzle about using stream device driver Mark Rivers
<2011>
2025
2026
