1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: fft
To: [email protected]
Date: Tue, 21 Jun 2011 15:05:02 -0500
On 06/21/2011 12:42 PM, Michael Davidsaver wrote:
Has anyone done a routine for the aSub record (or similar) which does an
fft?
My input is complex data (two waveforms I and Q) as a function of time
(512 samples). Data updates come at ~5Hz.
I was thinking of using
http://www.fftw.org/fftw3_doc/Complex-DFTs.html#Complex-DFTs
I have used that but with 512@5Hz you could probably use a
brute-force algorithm.
FWIW: I also implemented a (IMHO) quite optimized FFT
algorithm which used AltiVec/SSE but I couldn't it to run as
fast as fftw3.
Bottom line: if you need something fast + reliable (but code
size doesn't matter too much) then it's hard to beat fftw3.
Just make sure to configure it with altivec/sse if you want
to let it use your vector co-processor.
Cheers
- Till
Suggestions?
Re: fft Michael Davidsaver
Prev: RE: fft Jeff Hill
Next: Re: fft Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
