On 6/27/11 7:48 AM, Benjamin Franksen wrote:
>> This means you shouldn't try to
>> rely on EPICS_HOST_ARCH containing the string "64" when you're building
>> for a 64-bit CPU, and even if it does it isn't necessarily going to be
>> /only/ building for a 64-bit CPU.
> Hm, does that also mean I can not even rely on parsing the current directory
> to find out which target arch I am on?
Hi, Ben.
That's correct. For example, if I have EPICS_HOST_ARCH set to
"linux-x86" in my environment and ARCH_CLASS set to "i386
x86_64" in configure/os/CONFIG_SITE.Common.darwin-x86 in EPICS
Base, then when I do make in seq-snapshot-2011-06-24, the only
O.* directories in src/seq are O.Common and O.darwin-x86. So,
the O.darwin-x86 contains "fat" object files, libraries, or
binaries for both i386 and x86_64.
> Could I test the value of ARCH_CLASS
> in the Makefile to decide whether a test should fail or not?
That might work, but maybe not in the way you think. Say I
specify a 32-bit architecture *and* a 64-bit architecture in
ARCH_CLASS (e.g. i386 and x86_64). In this case, I think the
test would actually pass when building the i386 machine code but
fail when building the x86_64 machine code. As Andrew noted,
the EPICS build system does not invoke gcc for each ARCH_CLASS,
that's happening automatically behind the scenes, so I think you
would just see failures when building because the fat binary
includes the x86_64 machine code. And maybe that's fine? If a
fat binary (or library) would contain code that would be broken
if run on a particular architecture, then fail even though the
code would actually be OK for some of the architectures (i.e.
i386 in this example).
Lewis
- Re: Sequencer news: latest snapshot Benjamin Franksen
- Sequencer news: latest snapshot Benjamin Franksen
- Re: Sequencer news: latest snapshot Andrew Johnson
Re: Newport XPS and Motor record John Hammonds
Re: Sequencer news: latest snapshot J. Lewis Muir
<2011>
2025
2026
Re: Sequencer news: latest snapshot Pelaia II, Tom
<2011>
2025
2026
