1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer news: latest snapshot
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Mon, 27 Jun 2011 23:09:09 +0200
Am Montag, 27. Juni 2011, um 18:12:11 schrieb J. Lewis Muir:
> On 6/27/11 7:48 AM, Benjamin Franksen wrote:
> >> This means you shouldn't try to
> >> rely on EPICS_HOST_ARCH containing the string "64" when you're building
> >> for a 64-bit CPU, and even if it does it isn't necessarily going to be
> >> /only/ building for a 64-bit CPU.
> > Hm, does that also mean I can not even rely on parsing the current
> > directory to find out which target arch I am on?
> That's correct.  For example, if I have EPICS_HOST_ARCH set to
> "linux-x86" in my environment and ARCH_CLASS set to "i386
> x86_64" in configure/os/CONFIG_SITE.Common.darwin-x86 in EPICS
> Base, then when I do make in seq-snapshot-2011-06-24, the only
> O.* directories in src/seq are O.Common and O.darwin-x86.  So,
> the O.darwin-x86 contains "fat" object files, libraries, or
> binaries for both i386 and x86_64.
I must admit that I went into this discussion w/o any idea what "fat binary"
means. I know better now, and I understand the problem: with fat binaries one
has different target architectures inside a single binary. However, could we
not create a separate pseudo target architecture for such fat binaries? Maybe
with another separator character; I think '+' would be fine (and self-
explaining), so that we would have e.g.
  T_A = darwin-x68+x69_64+pps
> > Could I test the value of ARCH_CLASS
> > in the Makefile to decide whether a test should fail or not?
> That might work, but maybe not in the way you think.  Say I
> specify a 32-bit architecture *and* a 64-bit architecture in
> ARCH_CLASS (e.g. i386 and x86_64).  In this case, I think the
> test would actually pass when building the i386 machine code but
> fail when building the x86_64 machine code.  As Andrew noted,
> the EPICS build system does not invoke gcc for each ARCH_CLASS,
> that's happening automatically behind the scenes, so I think you
> would just see failures when building because the fat binary
> includes the x86_64 machine code.  And maybe that's fine?  If a
> fat binary (or library) would contain code that would be broken
> if run on a particular architecture, then fail even though the
> code would actually be OK for some of the architectures (i.e.
> i386 in this example).
Yes, that was the idea. However, with the current build rules for TESTPRODUCTs
I see no way to communicate the distinction from the Makefile to the test
script. By parsing the last part of the cwd I could find out the T_A, and if we
adopted the above proposal, I could match it with '64' inside the test
script...
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Sequencer news: latest snapshot J. Lewis Muir
Re: Sequencer news: latest snapshot Pelaia II, Tom
Re: Sequencer news: latest snapshot Andrew Johnson
Sequencer news: latest snapshot Benjamin Franksen
Re: Sequencer news: latest snapshot Benjamin Franksen
Prev: Re: Newport XPS and Motor record John Dobbins
Next: Re: Sequencer news: latest snapshot J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <2011>  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer news: latest snapshot J. Lewis Muir
