Hi John,
> If I look in the XPS web interface I don't see any errors reported
> there. Should I expect to see them there?
No, you would not see them there. You can use the terminal interface in
the Web page to translate error numbers into messages, but you won't see
messages as errors occur.
If the motor is moving normally, but is reporting that error, then I
wonder if perhaps it is being told to move a second time while it is
already moving, for example?
You can do
asynReport
to see the names of all of the asyn IP port drivers connected to this
XPS. There will be several. One is used for status on all axes, and
there is 1 per axis for issuing "move" commands. You can enable trace
debugging on these ports with
asynSetTraceIOMask "port",0,2
asynSetTraceMask "port",0,9
That sets asynTraceIOEscape (to see ASCII messages with escape
sequences) and asynTraceIODriver, to see messages from the asyn IP
driver.
With that level of debugging you should be able to see what commands are
being sent to the XPS, and which ones are working, and which are
resulting in the error you see.
Send the output of "dbpr myMotor 10" (which will print all the motor
record fields) and the contents of the stage definition file for those
motors, so we can compare maximum velocity, acceleration, limits, etc.
-----Original Message-----
[mailto:[email protected]] On Behalf Of John Dobbins
Sent: Monday, June 27, 2011 1:29 PM
To: [email protected]
Subject: Re: Newport XPS and Motor record
All,
Thanks for the various replies.
The stages actually move normally. And report statuses that would be
expected, "Ready from Homing", "Reading from Moving", ...
Also I have two different stage types connected and both types produce
this error.
The XPS configuration was generated by the XPS using that option as
available in the web interface. Limits, velocities, ... appear to be set
correctly. So I can't tell what the XPS is complaining about.
John
On 6/27/2011 11:57 AM, John Hammonds wrote:
> I once had a problem that the configured velocity (in the motor
record)
> was not allowed by the XPS. It returned the same error code. This
was
> a manually configured motor. We had to play around a bit to get the
> XPS configuration correct.
> John
> On 6/27/2011 10:52 AM, Pete Jemian wrote:
>> John:
>> What is your configuration in the XPS controller?
>> Can that have some influence?
>> Pete
>> On 06/27/2011 09:51 AM, [email protected] wrote:
>>> Hi,
>>> It could also be that the XPS axis is in the wrong 'state'. I think
>>> it needs to be in 'ready state' (states 10 to 13) to receive move
>>> commands.
>>> I updated the XPS driver recently. So in the next release of the
>>> motor support module the driver should indicate if there is a
problem
>>> (via the motor record MSTA field). So if the axis is in a state
which
>>> means you can't move it then you will be notified by the record
going
>>> into alarm state.
>>> Cheers,
>>> Matthew
>>>> From: [email protected] [mailto:tech-talk-
>>>> [email protected]] On Behalf Of Mark Rivers
>>>> Sent: 27 June 2011 15:17
>>>> To: John Dobbins; EPICS Tech-Talk
>>>> Subject: RE: Newport XPS and Motor record
>>>> Hi John,
>>>> If you translate that error code, -22, using ErrorStringGet in the
XPS
>>>> Web terminal interface you will get:
>>>> 0,Error -22 : Not allowed action
>>>> So there is something illegal about the request you are making. Is
it
>>>> possible that you are exceeding a soft limit, etc.?
>>>> Mark
>>>> Sent: Monday, June 27, 2011 8:38 AM
>>>> To: EPICS Tech-Talk
>>>> Subject: Newport XPS and Motor record
>>>> All,
>>>> I am using Motor Record R6-4-4 , EPICS R3.14.9, ASYN 4-9 with a
Newport
>>>> XPS controller.
>>>> When I send a new position to an actuator I get a messages in the
IOC
>>>> like this:
>>>> epics> 2011/06/24 12:35:35.552 SendAndReceive unexpected response
>>>> =-22,GroupMoveAbsolute (GROUP2.POSITIONER,12.00003072008),EndOfAPI
>>>> otherwise everything seems to be working, i.e. motor responds
properly.
>>>> Does someone know what this means? The XPS set-up portion of my
st.cmd
>>>> script is below.
>>>> Regards and Thanks,
>>>> John Dobbins
>>>> Cornell University
>>>> The XPS set-up portion of my st.cmd script:
>>>> # cards (total controllers)
>>>> XPSSetup(1)
>>>> # card, IP, PORT, number of axes, active poll period (ms), idle
poll
>>>> period (ms)
>>>> XPSConfig(0, "erpxps01", 5001, 3, 10, 500)
>>>> # asyn port, driver name, controller index, max. axes)
>>>> drvAsynMotorConfigure("XPS1", "motorXPS", 0, 3)
>>>> # card, axis, groupName.positionerName, stepsPerUserUnit
>>>> # PR50CC rotational stage
>>>> XPSConfigAxis(0,0,"GROUP1.POSITIONER",100)
>>>> # CMA-12CCCL linear stage
>>>> XPSConfigAxis(0,1,"GROUP2.POSITIONER",20480)
>>>> XPSConfigAxis(0,2,"GROUP3.POSITIONER",20480)
- Re: Newport XPS and Motor record John Dobbins
- Newport XPS and Motor record John Dobbins
- RE: Newport XPS and Motor record Mark Rivers
- RE: Newport XPS and Motor record matthew.pearson
- Re: Newport XPS and Motor record Pete Jemian
- Re: Newport XPS and Motor record John Hammonds
Re: Sequencer news: latest snapshot Pelaia II, Tom
Re: Sequencer news: latest snapshot J. Lewis Muir
<2011>
2025
2026
<2011>
2025
2026
